need help with buying a knock sensor
Old Jul 18, 2020 | 02:34 AM
wtxkidd's Avatar
G35 Coupe
okay here is the deal, i bought a 2004 G35 Coupe, and running a self diagnostics on it the only code the car threw was a knock sensor, P0328.. turns out rats had chewed the harness off but since i have the whole intake manifold pulled out i thought, might as well be safe and replace the actual knock sensor and the harness, now here is my problem,, i bought the knock sensor off rockauto and everything said it would fit my car but when it came in it turned out that it wast actually gonna fit my car,, the two little prongs on the side of the plug are like even when they need to be offset and i spent a good 180 on sensor and harness and its frustrating cause i had to send it back and also have my car taken apart while i wait. please help me find the correct one for a 04 G35 COUPE
Old Jul 18, 2020 | 06:45 AM
victor0206's Avatar
Are you sure you got the right one? There痴 quite a couple different ones on there depending on your car if you read the description
Old Jul 18, 2020 | 09:04 PM
Jeffreybonilla5's Avatar
Visit z1motorsport.com they will hook u up with a good deal nice and fast wont regret it. Also i believe the sedan used a diffrent type but dont quote me
Old Jul 20, 2020 | 12:26 PM
wtxkidd's Avatar
G35 Coupe
Jeffery yea I believe that they are cause the little prongs on the side are offset for a coupe and even for a sedan, I went to Z1 for the whole harness so if I still get the code I値l go there thanks
Terry_G35
May 9, 2020 01:39 AM
AL Berroa
Mar 13, 2020 11:37 AM
Danny_G
Nov 14, 2019 12:54 AM
GEELO619
Oct 12, 2019 09:13 AM
ptbsn8
Nov 20, 2010 05:46 PM
