Wheel fitment help
Old Jul 21, 2020 | 06:11 PM
Damitrius's Avatar
Silver g35 coupe.
Wheel fitment help
Help!!! 2004 g35 coupe on truehart coilovers Plan on running 19x11 +15 with 235/35/19 up front and 245/40/19 in the rear. Will I need any fender work or camber kit to run this setup?
Old Jul 21, 2020 | 06:53 PM
Damitrius's Avatar
Silver g35 coupe.
19x11 +15 all around*
Old Jul 25, 2020 | 01:36 AM
Magneu's Avatar
5 Year Member
G35C 5AT
I know that 18x10.5 +15 is confirmed to work, see below:
https://g35driver.com/forums/media-s...c-coating.html
From the pics there, the extra half inch of rim width/one inch of rim height shouldn't be a game-stopper, but it will limit how low you can go. Stock tire size in rear is 245/40/19 on the 19x8.5 Rays, so I would seriously consider upsizing your width a bit; that is QUITE a bit of stretch you're planning for, the tire size is two inches narrower than the rim.
The front is what worries me, I currently have 18x9.5 +25 on my fronts, and I'm fairly certain my (currently rears) 18x9.5 +15 will fit fine (gonna get that square eventually!). 19x11 +15 is a lot of extra rim considering how far the front has to turn. Someone's most likely made it work, but I'd check out FitmentIndustries, they have a huge selection of any model with the exact specs of what's on the car with any notes (rolled fenders, cut fenders, etc).
Good luck!
Old Jul 30, 2020 | 09:24 PM
haynV35's Avatar
White G35 Sedan
imo that sounds like a roll and camber is needed, but depends how low you are/planning to go.
should use willtheyfit.com and you can use that reference to measure and get a visual of how they may come out.
Old Aug 1, 2020 | 01:08 AM
DannyV123's Avatar
https://www.rimtuck.com/search/thumb...odel=G35+coupe
Schparky
Apr 28, 2020 09:48 AM
Swiftskillz
Mar 30, 2016 03:15 PM
