rear spring issue?
Old Sep 10, 2020 | 06:10 AM
ashleytea666's Avatar
6spd MT, coupe, stock
rear spring issue?
ok so everytime i drive my car theres this like "whirring" noise that ( in my opinion) sounds like the tire is rubbing against something. it almost sounds like the exhaust does but its way to constant( i can hear it even if i throw the car into neutral for a second) i just replaced the whole front suspension so i feel like it has something to do with the rear springs being worn and causing the camber or whatever to be off and make the tire touch something its not supposed to... am i on the right track? i have a video but its kind of hard to hear the noise over the other sounds. oh and it always smells like burnt rubber after i stop driving.
Old Sep 11, 2020 | 10:30 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I'd check your wheel bearings, especially if the noise is getting worse with increasing speed. They are a known pattern failure for G/Z's.
When the front one went out on my car, it made a loud 'hmmmmmm' noise that got very droney at 60+ mph. It was the left front, so it got worse on right turns, especially when cornering hard.
If the rear of the car is sagging (ride height wise) than I'd consider springs a suspect, or maybe something is bent.
Usually if a tire is rubbing, you'd be able to tell by looking at it. Rubber rarely wins against metal.
Old Sep 12, 2020 | 12:06 AM
MooseLucifer's Avatar
5 Year Member
blk
Tires rubbing on the car even at parking lot speeds will be very noticeable, it'll make loud noises and/or smoke.
Bad alignment would accelerate bearing wear which could cause the noise, and longer trips on the highway could bring the tire temperatures up to a stinky range.
Old Sep 13, 2020 | 09:00 AM
i guess that means one of my front wheel bearings out going bad AND my rear springs -.- huzzzah!
Old Sep 13, 2020 | 09:07 AM
5 Year Member
blk
What makes you think your springs are worn? Steel springs really shouldn't wear out much, if at all, for decades (without extreme use or temperature changes).
Old Sep 15, 2020 | 07:20 PM
Its sagging on the drivers side rear end
Old Sep 15, 2020 | 07:22 PM
And if the sag isn't from the spring which parts of the suspension could cause it to sag so much on one side?
Old Sep 20, 2020 | 02:53 PM
5 Year Member
blk
It's possible the spring, sway bar, or a control arm is bent or damaged, do you have any pictures?
Old Sep 21, 2020 | 12:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take a measurement on a flat level surface from the road to the highest point at the wheel arch (chassis wheel well at the outer edge of the fender. Verify your tire pressure is correct before taking the measurements.
Here is the wheel arch height measurements from the FSM.
Theanimedude
Oct 7, 2010 09:22 AM
GarGamel
Jun 2, 2010 12:36 AM
Asad_A203
Canada
13
Aug 25, 2008 08:13 PM
dunglan7
Jun 19, 2008 11:10 AM
ltrrtl218
Nov 12, 2007 02:35 PM
