Sawtooth like metal shavings in oilpan, HELP!!
Old Oct 3, 2020 | 11:32 PM
Kane Stanford's Avatar
2005 manual G35 coupe
Hey so hopefully I can find someone here that knows anything about this issue of mine. I have an engine that’s been rebuilt( only about 900ish miles on it) well I’ve changed the oil in it around 400-500 miles and here recently noticed a small oil leak on my pan and was going to re seal my pan. While draining and pulling the pan off I noticed small bits of saw tooth like metal shavings in the oil? Anyone know what I need to look into next or do I currently plan to contact the engine shop Monday that I took it too if I have not figured this out by then. Again any help will be more then appreciated because I am just trying to figure out how bad this is and what it is, thanks.
Old Oct 4, 2020 | 10:24 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pictures pictures pictures.
Old Oct 5, 2020 | 09:32 PM
MurdaG's Avatar
It's got 2 doors 😂
Dude if you got warranty I'd take it right back, 900 miles on motor and already seeing metal, na something aint jiving.
Old Oct 10, 2020 | 07:43 AM
cleric670's Avatar
BANNED!!!
Yeah something ate itself up, motor is probably shot.
Old Oct 10, 2020 | 11:02 AM
telcoman's Avatar
Veteran: Army
Do a compression test!
If all cylinders are normal just run it till it dies.
Carry a screwdriver with you so you can remove your plates when the death occurs.
If your engine was rebuilt where were the parts/rings obtained from? If China that may explain?
Andruz24
Feb 3, 2018 04:10 PM
Jonconusaf
Dec 26, 2015 01:31 AM
