High pitched buzzing sound coming from under the rear of my G
Old Oct 19, 2020 | 01:18 PM
Bfish's Avatar
6mt g35S w/brimbo, aero and premium package
Hey everyone, im new to G ownership I bought mine 2 months ago and its mostly been sitting but ive been driving it a bit once a week. Its got 212k km on it and a few things done to it but nothing done to the engine. Last time I drove it I started to hear a high pitch buzzing noise when the car is in idle coming the from under the rear between the wheels, moreso on the passenger side it almost sounds like speaker feedback and I have the bose sound system ive heard that is problematic but its completely off when this is happening, from
what ive read it’s probably the fuel pump but im not sure my friend mentioned dif whine but it happens in idle so I dont think thats what it is. Ive read a lot of threads about this but its hard to know if people are talking about the same noise. Ive attached a video of the sound recorded from the passenger side. Any suggestions would be greatly appreciated as im kind of worried. Would I need to replace the pump? People said it can drive like that for a while or its fine and just loud but it doesnt sound right to me.
Old Oct 19, 2020 | 01:30 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Does it make the whine when you initially turn the key *before* you start the engine? The fuel pump primes for second or so when you initially turn the key.
If you can narrow it down to the pump, then its probably worth the time to replace it prior to it leaving you stranded....
Old Oct 19, 2020 | 01:36 PM
Bfish's Avatar
I tried to do that and I think I heard it a bit but not as loud and only for a second but its hard to tell ill try again tonight when I get home from work and let you know, if it isnt the fuel pump do you have any other ideas as to what it could be?
and when I see if it makes the noise while priming should it be from a cold start? Like if I start the car before and it primes will It not make the noise because theirs already pressure built up?
Old Oct 19, 2020 | 03:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The system doesn't prime, this is a returnless system so it maintains the fuel pressure even with the key off. Take a video of the sound and post it to youtube then put the link here and it will embed the video.
Old Oct 19, 2020 | 03:49 PM
Bfish's Avatar
hopefully this works I tried to attach before but it didnt work
also if the system doesnt prime I wont be able to hear it in key possition 2 with the engine off?
Old Oct 19, 2020 | 03:54 PM
cleric670's Avatar
BANNED!!!
Sounds like a fuel pump whine to me, if it makes the sound for about one second with the engine off and key turned to ON position then it's almost definitely the fuel pump.
Is it loud inside the car or something? If you don't hear it inside the car then I wouldn't worry about it.
Old Oct 19, 2020 | 03:56 PM
cleric670's Avatar
BANNED!!!
Originally Posted by Bfish
Video of sound
It turns the fuel pump on for 1 second yes (all gasoline cars do this as part of the pre start self check), but it doesn't need to build up a prime since it's already under pressure.
EDIT: Remove the rear seat cushion, two tabs in the front of the seat you pull forward then lift the seat cushion straight up. This will access the pump and sub pump flanges, it should be a noticeably louder sound if it's actually coming from the pump.
Old Oct 19, 2020 | 07:33 PM
Bfish's Avatar
I did what you said and didnt hear anything from the pump but as soon as the car started I heard the noise, its also hard to tell cuz I need a new drive belt bad so it squeals on startup most of the time ive got that and the serpentine belt going to replace both. The noise is only noticeable with the windows down but its definitely there, when I went to life the backseat its already out on the side with the pump im assuming the previous owner knew about this issue but somehow did a quick fix or something to silence it while I test drove.
I also noticed that im actually getting water leaking into the rear drivers side seat and the floor matts are damp any ideas what this could be?
on top of that I noticed the drivers side airbag tab is missing on the pilar does this mean its went off? It doesnt look like anythings been repainted on the car but maybe it was in an accident? Theres none ever reported on the cars history.
This is my first car and im pretty inexperienced with them in general but Ive been researching for a while and an willing to learn, im an electrician by trade so ive got no issue getting my hands dirty. Any help is greatly appreciated.
Old Oct 19, 2020 | 07:35 PM
Bfish's Avatar
The rear seat cushion tab was already liften on the passenger side so I think the previous owner knew about this. I dont hear it when I turn the key without turning over the engine. Im stumped.
Old Oct 21, 2020 | 10:46 PM
TokkioDrift's Avatar
04 6mt Coupe - motordyne 5/16 ART pipes TDX2; KWv2; Hotchkiss; custom seats.
Leaks are a pain to trace, but I would start by clearing the sunroof drains (there is a sticky on this somewhere - I like to use weed eater line chased by warm water or compressed air). I'm currently helping to restore a car that sat under an oak for two years and has crazy water damage in the cabin from pollen and debris clogging the drains. The suspicious pillar cover may actually point to the source of your leak as the sunroof drains run down each pillar with connections/points of failure along the hose.
For the whine, try pulling the radio fuse and maybe the acc fuse to eliminate any weird speaker/amp interference stuff. My old honda had a poblematic oem amp that made weird static pulses only when the engine was running through the rear speakers when the radio was off and pulling the acc fuse was the only thing that stopped it.
Old Oct 27, 2020 | 01:56 PM
Bfish's Avatar
The leak is definitely coming from that side so I think he tried to fix it before I bought the car but realized its such a pain and gave up, when I changed the belts I noticed one had been changed and the one that wasnt the bolt was seized so I think he gave up on that too, he got the car from a friend who built it but had it sitting for a while to work on other projects (r32 gtr and 240sx)
I also started hearing a “wubwubwub” noise coming from the rear of the car and it is clearly rotational I think it comes from the wheels, it speeds up and slows down with the car, any ideas? Maybe I just need to balance the tires or do an alignment. But I also read it could be tire tread separation and my friend who knows quite a bit about cars said it could be my breaks as I havent been driving it much so they have been getting rusty and the handbrake has been on so maybe the pads are getting stuck or something?
Old Oct 30, 2020 | 09:36 AM
cleric670's Avatar
BANNED!!!
wubwubwub sound from tires is almost always worn/separating tires. Sometimes wheel bearings but on our cars those typically make more of a steady "whining" sound.
Old Oct 30, 2020 | 04:10 PM
Bfish's Avatar
I thought that aswel but I just changed the rims and tires to winters and it still makes the noise, im thinking it could be the brakes are rubbing it had been sitting for almost two months rarely being driven and the handbrake was on what do you think? Also could it be the alignment? Its got camber arms and a tiny bit of camber ok it maybe they loosened over time? Again im new to this so these are only guesses
Old Oct 30, 2020 | 06:44 PM
cleric670's Avatar
BANNED!!!
Jack up each end of the car and spin the tires by hand to see if it's something obvious.
infini_
12
Dec 11, 2019 11:13 AM
ScraggleRock
Drivetrain
Dec 1, 2015 11:11 AM
Dubfound
Nov 3, 2006 05:10 PM
