M Style Spoiler for 06 G35 Coupe
Old Mar 5, 2021 | 06:58 PM
Blossom's Avatar
Infiniti G35 Coupe 6MT
Question M Style Spoiler for 06 G35 Coupe
Hey Guys!
I've read the other posts about the m style spoiler from years ago but can't seem to find a link and today I finally decided to sign up for the forums after just casually browsing for the last few months,
So I'm wondering if anyone has seen an M-Style Spoiler (Below) for sale that would fit a g35 coupe? I've seen one for the G37 coupe but I'm not sure about the size differences so I don't know if it would fit the G35.
https://www.ebay.com/itm/Carbon-Fibe....c101195.m1851
Old Apr 13, 2021 | 11:55 AM
Blossom's Avatar
bump
Old Apr 13, 2021 | 12:26 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would buy a cheapo knockoff version to test fitment, if the contour and length are correct then order the real thing. Worst case you're out $100 and can still recoup cost by reselling it locally.
I suspect what you'll find though is the V35 platform trunk is very narrow and those style of spoilers don't appear to have much reinforcement at the far edges so it will probably be very loose and floppy. Spoilers designed for the V35 coupe narrow trunk are typically very reinforced if they protrude off the sides of the trunk like the OEM spoiler does.
You might be able to fab a backer plate for it though to add some rigidity if needed. Also you might end up buying a cheapo spoiler that DOES fit the V35 coupe (like an OEM spoiler) then slicing/sanding it down to use as a contour adapter with the correct bolt pattern so you can then epoxy/bond the new spoiler to it.
Body work like this is fun, be creative.
Jmike8886
Aug 8, 2014 01:06 PM
Coderedd
Jan 31, 2013 07:10 PM
a008580152
May 1, 2012 12:32 AM
TheloniousMonk
May 12, 2011 12:04 PM
capncrunch
Oct 5, 2009 10:38 PM
