My cel came in and got codes p1148, p1168, p1031, p1051
Old Jul 6, 2021 | 12:03 PM
Atjstballin's Avatar
G35 coupe 6mt
Im new to these car readers and I'm not sure what I'm supposed to replace? My car had a gutted cat on one side, could that be the issue. And sometimes on a rare occasion the car will fail to start but usually will on the second try.
any help on what to do.
Old Aug 13, 2021 | 01:08 AM
DARKslide's Avatar
G35 COUPEbase Murdered Out Black with Black and Grey Leather Interior. Just got it. The build begins
I just threw all the same codes did you ever figure out what was going on with you Ride??
Old Aug 13, 2021 | 10:31 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
First check for intake and exhaust leaks, then remove the cats and use a borescope or inspection mirror/flashlight to check for melted spots on the element.
When both pop up at exactly the same time I usually suspect vacuum/exhaust leaks. Also spray some MAF cleaner in the MAF to rule it out.
Realtime OBD2 scan both upstream O2 sensors and make sure they are cycling properly.
Old Aug 17, 2021 | 11:03 AM
G35 coupe 6mt
I checked for any exhaust leacks by sticking a shop vac in the tail pipe and found air hissing out of multiple gaskets think that might cause the codes?
Old Aug 19, 2021 | 09:46 PM
cleric670's Avatar
BANNED!!!
Depends on which gaskets but if it was either engine-headers or headers-cats then yes.
Old Aug 20, 2021 | 09:24 AM
seymore4's Avatar
m56
Check your fuses
Old Aug 20, 2021 | 09:45 AM
cleric670's Avatar
BANNED!!!
Good point, all that stuff should come from fuse 85 in the IPDM.
Old Aug 20, 2021 | 09:49 AM
seymore4's Avatar
m56
That's my first stop when you get 1148 and 1168 at the same time and haven't been messing with the sensors
Old Aug 23, 2021 | 07:38 PM
DARKslide's Avatar
my scanner doesn't have the real-time capability is it possible to check the 02 sensors outputs with self-diagnostics. I'm looking up what reliable readings should look like from the upstream sensors I'm just not sure how to get the reading from the car. If I have to replace the sensors it's looking like the cost will be about 125 to 140 apiece (NTK brand.) I don't really think this is the time to experiment with eBay deals when the sensor is such a critical part of the system.
that being said id like to know if that's the problem first but a new tool expense on top of two upstream sensors would be a big hit. It threw the codes one time only a week ago. I reset the ECU that night to drive it home, it was raining, and haven't seen them since.
I do know it's not running the way it was. over the past five weeks, I've noticed the idle being off. it's so subtle that other people can't hear thru the exhaust but I know how it sounds like right after a full tune and it's definitely slower and has a lope to it still holding at 650, but like I said it's subtle. my gas mileage isn't great but it's a project car that I brought from the dead it was never good I just really didn't care but everything together suggests possibly worn o2 sensors at least.
you guys are awesome and any advice you have the time to pass on would be a huge help thanks.
Old Aug 23, 2021 | 07:54 PM
cleric670's Avatar
BANNED!!!
Check the fuses as Seymore4 suggested.
3000vr4tt
Oct 8, 2013 09:26 PM
cody08cofer
Jul 2, 2011 11:29 AM
aalqaedi
May 13, 2011 03:01 PM
ndbolourchi
Mar 14, 2005 08:53 PM
