Squeak When Switching Gears
Old Aug 25, 2021 | 03:39 PM
BlvCkMambA17's Avatar
2004 Infiniti G35, 6 Speed Manual, Stock at the moment
When I go to switch gears in my g35 it makes a weird squeak when I put the clutch pedal in. I’ve changed and the hard ware around the pedal and switched my clutch and flywheel and still have the same results. Please help
Old Aug 26, 2021 | 03:22 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Others are probably better qualified, but I think you're likely needing some grease on the moving parts of the pedal assembly. Don't grease any part of the master cylinder without verifying it should be done. There's a pin and moving parts attached to an assisting spring that all can squeak if not greased. You can see pictures in the first post here that might help you. Find the places with cotter pins and grease those areas.
Old Aug 26, 2021 | 10:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is this t squeaking inside the cabin or under the car.
SlickSilverG
40
Mar 19, 2015 12:02 AM
FI'ed G
Drivetrain
May 18, 2011 12:36 AM
cyt_411
Jan 24, 2007 01:04 PM
