Kinetix plenum
the plenum spacer is designed to even out and balance air flow per cylinder since the stock plenum is designed with that weird downward slope towards front of engine . The Kinetix doesn’t have this problem since it’s a performance mod it does all that for you and then some. as for the adding the spacer AND the kinetix i’m not sure on hood clearance seeing how i don’t have that plenum, also wouldn’t see the need for the spacer since the kinetix is an upgrade from stock
