Will 19x11 with +33 offset fit on my stock g?
Will 19x11 with +33 offset in front and rear with stock suspension on my g35 coupe?
Yes, but you may need to roll your fenders. I have a 19x10 +15 in the rear with a 275 tire and I had to roll my fenders. Your higher offset bring your lip edge inwards by 0.711" compared to my setup, but you then have another 0.5" of additional width on either side of the rim (10" vs 11"). So in effect the face will sit at -0.711" + 0.5" = -0.211". It will be more inwards compared to my setup. In short, your rim will be almost the same as my rear or rather within 0.211" of it (actually more inwards).
Also it will look whack on stock suspension, you should have it lowered.
Ahh makes sense thank you. I don’t wanna go too low tho where I’m at the point of worrying about scraping over every single bump. Should I go lowering springs or coils?
