Help need info about the sunroof panel replacement with OEM parts
Old Jan 12, 2022 | 08:41 PM
Forumaccount's Avatar
None
Is it possible to replace the g35 with sunroof with the old roof panel that has no sunroof ? I have seen a roof panel parts from:
www.discountoeminfinitiparts.comhttps://www.discountoeminfinitiparts.com/About-Us-s/1.htm
​​​​​​Is it easy ? Does it need welding or etc I hope it's not.I just want to replace the parts immediately without welding,grinding etc ... Thanks
Old Jan 12, 2022 | 09:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
EDIT: I'm highly suspicious that you're a bot, if anyone else sees suspicious activity on this thread or from this account PM me and I'll come down on them with the fury of a thousand suns. If you are a legit account and are asking a legit question then I apologize in advance, see the next few lines for my original answer.
It's basic body work, yes it will require welding, grinding, sanding, filler, paint. It's definitely not a simple bolt-in component.
You would also need to replace the entire headliner with one from a non-sunroof model.
My question is why would you ever want to delete a sunroof?
If you're talking about just replacing the glass or track, well that's fairly straightforward stuff.
ryangarland92
Interior
Jun 5, 2015 10:31 AM
Jeff92se
Engine - Intake/Fuel
Aug 24, 2012 06:47 PM
avion
Aug 16, 2008 08:37 PM
JoeyG35
Nov 15, 2005 01:41 PM
