Differential removed, what should i do?
Old Jun 8, 2022 | 10:04 AM
Zeromaz's Avatar
clean
I'm going to have the differential out to install some bushings. Anything you guys recommend I do while I have this thing out? Anything you'd recommend I do to the subframe while that is out? This is a 2005 AT coupe. Daily spirited driving. No racetrack stuff.
Old Jun 8, 2022 | 11:42 AM
LoSt180's Avatar
A Nismo or Z1 diff cover would be a simple thing to do while it's off. Plus obviously fresh fluid. Not much else to do unless you're going deeper into mod territory.
Old Jun 10, 2022 | 10:49 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Subframe collars if you want it even stiffer. You can always do that later though since it doesn't need to have the diff removed.
Spray any rust with under carriage spray.
Check your rear wheel bearings and the rest of your rear suspension bushings.
kethnguy
Northern California
Dec 29, 2015 03:14 PM
LxV Socal
Mar 18, 2013 02:51 AM
XDR-V35
Apr 7, 2012 08:48 PM
Billabongi
Florida G Club
Feb 10, 2012 11:43 AM
whoisthis
Oct 23, 2011 11:09 PM
