Fuel pump acting up
Sep 29, 2022 | 04:11 PM
Quote: So today I installed a new fuel pump assembly and a picknpull ipdm. I go to put the ignition on and after a few minutes the “Service engine soon” light comes as in sequence with the fuel pump turning off and on. The light and pump will turn on and off with each other. Only code i’m getting is about a knock sensor bank 1 and I don’t think that will cause this issue. I am thinking the ECU is toast. I’ve checked the ecu fuse and relay as well as the fuel pump fuse and relay. I’m lost at this point. Anyone got any ideas?
Thanks in advance!
It appears that installing a new/used IPDM may require you to adapt it (Audi speak) to the ECU.
Q: was the original IPDM actually bad?..or did you replace it with the FP just because?
I would put the original IPDM back in and see what happens from there.
https://g35driver.com/forums/souther...-re-learn.html
Reply 0
Sep 29, 2022 | 05:07 PM
There are a few different IPDMs
There is a white sticker on the side, it needs to be the correct parts INTERCHANGE number, doesn't necessarily need to be the exact same number.
For examples the 2004.5+ cars can use Nissan part numbers 284B7-AQ006, 284B7-AQ016, 284B7-AQ066 or the current revision 284B7-AQ01B
2003-2004.5 5AT uses 284B7-AL500, 284B7-AL50 or the newest revision 284B7-AL51A
2003-2004.5 6MT uses 284B7-AL505, 284B7-AL50B or the newest revision 284B7-AL51B
Reply 0
Oct 2, 2022 | 11:56 PM
I put the old IPDM in and it had the same issue but no windshield wiper issue like the junk yard one. I ended up buying a used IPDM with the same number from the OG one and it did the same issue, ecu output to the fuel pump fuse was going in and out. I’m assuming an ECU issue still.
Reply 0
