infiniti g35 sports coupe engine shuts off
Old Jan 21, 2023 | 07:34 PM
dshah's Avatar
infiniti g35 sport coupe
Hy fellas
i hope you all are well,
so my infiniti g35 s coupe 2003 automatic, turns off its engine without warning or anything
it started few days ago, in the start it happened like the car lost its power for like 1 sec while i was driving and then again got in power and yesterday the car completely shutdown while i was on the road then i had to pull over and start it again
it happened 2 time yesterday and today i was waiting in line of drive thru and my car was in neutral and the car shutdown while even in neutral and then i started it again but it took some power for battery to start it, didn’t start like normal and vdc off, slip and service engine lights lighted up on the dashboard
your advice would be really helpful as i’m a student and I don’t wanna get into any big problem
i bought this car like a week ago
It was like this after engine turned off in neutral before i had to start it again
File Type: mov
Old Jan 22, 2023 | 12:21 AM
Scorpi0's Avatar
If the check engine light is on just take it to an auto parts store and they can read the code for free. Thatll tell u whats wrong with it exactly.
But from the sounds of it, I would say its a bad camshaft or crankshaft sensor. Those sensors failing is pretty common on these cars.
Old Jan 22, 2023 | 03:17 AM
dshah's Avatar
there’s no engine light, could it be a problem of battery cos after shutting off engine the car struggles to turn on again
Old Jan 22, 2023 | 03:34 AM
Scorpi0's Avatar
Does the engine crank fine? If its cranking fine then the battery is good.
Or is it just cranking but it wont start?
Old Jan 22, 2023 | 10:17 AM
12pawsinn's Avatar
Relatively stock
Until you give us codes, we can sit here for ( infiniti ) coming up with theories and ideas and keep guessing.
it's most likely the cam position sensor. But go find out
Old Jan 24, 2023 | 12:10 AM
dshah's Avatar
Codes
So the codes areP0345
Camshaft Position Sensor "À" Circuit Bank 2
P0171
System Too Lean Bank 1
Old Jan 24, 2023 | 01:42 AM
12pawsinn's Avatar
Relatively stock
P0171
Now you and all of us know the problem.
And we know the solution 😏
Replace the cps
Old Jan 24, 2023 | 10:11 AM
G2B35AGN's Avatar
Use only OEM or Hitachi (OEM mfr) sensors. Lots of evidence throughout the forum that cheap aftermarket sensors either don't work or don't last. Don't be that guy!
Old Jan 28, 2023 | 11:11 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ignore that bank lean code for now, it might have been caused by the engine stalling. Replace the CPS, clear codes, rescan for codes and see if it comes back.
Old Feb 5, 2023 | 12:37 AM
dshah's Avatar
Update
Hy everyone
i replaced the camshaft sensor bank 2, and ecu reset, but the problem is still there it stalls and turns off in low rpms
and the code is still there p0345
Old Feb 6, 2023 | 04:31 PM
cleric670's Avatar
BANNED!!!
Just to verify, you replaced the one on the DRIVER SIDE correct?
If so, did you use a Genuine OEM Nissan or Hitachi sensor?
Old Mar 10, 2023 | 04:22 AM
dshah's Avatar
Update
No I ordered them from amazon and both cam shaft and crankshaft, when i cleared the codes the codes didn’t come for 1 month but the problem was still there, today service engine light has turned on again and problem is still the same
Old Mar 10, 2023 | 01:03 PM
cleric670's Avatar
BANNED!!!
It's a pretty common issue for all aftermarket sensors to fail quickly, or to just not work at all.
Strongly suggest either Hitachi (the OEM manufacturer) or a genuine Nissan sensor.
Old Mar 10, 2023 | 05:18 PM
Scorpi0's Avatar
Yup, aftermarket sensors dont work well with these cars. I have tried it too and found out the hard way.
Buy an original Nissan sensor or a Hitachi. And dont buy the ones on ebay that say “OEM”. Theyre usually around $50 bucks and even come with Nissan packaging but they are FAKE!!
Old Mar 13, 2023 | 06:36 PM
shurur's Avatar
2003 G35 Coupe
I went through 4 cheap Amazon sensors on the audi before I wised up and got some from rock auto.
Listen to these guys.
Those cheap sensors don't work on any car...period.
