power steering solenoid connector
Old Feb 18, 2023 | 08:38 PM
ashleytea666's Avatar
6spd MT, coupe, stock
the wiring for the connector for my power steering solenoid broke right at the end of the connector so i cant even just try to fix the wires...does anyone know what the name of the pins inside the connector are? if i can get new pins ill just re-pin the old connector
Old Feb 19, 2023 | 09:54 AM
Scorpi0's Avatar
Can u poat a pic of what toure talkin about?
Old Feb 21, 2023 | 12:07 PM
Urbanengineer's Avatar
Honesty not sure. You really need to disassemble the connector and then go from there.
Old Feb 21, 2023 | 07:26 PM
Old Feb 21, 2023 | 07:32 PM
now that i think about it i could probably just replace both sides of the connectors and that would be the same as re-pinning the old connector
Old Feb 25, 2023 | 01:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah that would work, the pins inside all Nissan connectors are replaceable though, just takes a little poking around to figure out how they release for each harness, you can youtube search things like "depin nissan harness connector" and watch a few videos to get an idea how they depin.
You can then buy replacement pins online, normally for Nissan pins you use a micrometer and measure how wide the pin is, they use 4-5 different standard sizes, all measured in MM.
Once you've done a few different cars you start to see the pattern of how Asian vs. American vs. German harnesses are depinned.
gaboboost
Steering & Suspension
Dec 28, 2016 01:36 PM
Solekeeper
Feb 15, 2009 03:42 AM
3Point5Sedan
Dec 30, 2007 01:29 PM
LuXXXz
Aug 21, 2006 08:03 PM
