Sunroof Assembly/Track Repair
Old Mar 20, 2023 | 02:38 PM
FRISCO6MT's Avatar
Hi fam!
2004 G35 Coupe 6MT sunroof hasn't worked in years; last mechanic advised me of needing an entirely new roof track assembly. Can someone point me to the direction of the correct parts and/or recommedations?
Old Mar 21, 2023 | 02:01 AM
Scorpi0's Avatar
Have u tried re-calibrating it yet? Its super easy and might just be all u need.
Old Mar 23, 2023 | 09:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would also check to make sure it's not just a blown fuse.
Unplug the sunroof motor harness and see if you have 12v on the white wire, and the yellow/black stripe wire, with the ignition ON.
Recalibration is simple and needs to be performed anytime you unplug the sunroof harness, turn ignition ON, hold the close/tilt button until the sunroof automatically tilts up and down, then release the button. Now do that button hold a second time and this time it will open the sunroof, close, tilt up, tilt down, then stop, release the button once this is all performed and it has stopped moving.
NYT
Canada
Jun 8, 2015 11:20 AM
harley01
Dec 29, 2006 10:04 PM
