MSD Ignition 82796 - Blaster Red Ignition Coil
Old May 13, 2023 | 12:26 AM
12pawsinn's Avatar
Relatively stock
I searched a few times and on Google.. just wondering if anyone has real life experience with these..
Old May 13, 2023 | 09:51 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Doesn't make any difference for N/A applications, typically hotter coil packs run 3k to 4k more volts which does make a difference for high boost applications. Lets you run a little more spark plug gap than you would normally, high boost you might be down to like 0.012 gap on stock coils, high energy coils you can do like 0.015 - 0.018 which makes a big difference since that's 25% more gap.
Stock N/A application where you're already running 0.043 gap it won't make a bit of difference, that's already PLENTY of spark plug gap for complete ignition and increasing to 0.045 - 0.048 is only a 5% increase. You would probably see a zero WHP gain.
Old May 13, 2023 | 09:46 PM
12pawsinn's Avatar
Relatively stock
thanks!!! I'm building up and going turbo just trying to get parts collected over the summer and winter.
Definitely appreciate the help
TINMAN
Picture Share
2855
Aug 10, 2019 11:45 PM
kraken316
NorthEast
Apr 21, 2007 03:02 AM
