Obd2 port not working & no SES light on accessory mode
Old Jun 26, 2023 | 10:09 PM
RA062623's Avatar
Hi everyone, I’ve been looking through old posts and searching through forums everywhere to get some sort of guidance.
My TPMS light and ABS light were illuminated so I took my mx808 scanner out to check the codes, only to discover the Obd2 port can’t read my scanner. Today I checked / replaced the fuses for the cigarette lighter and the data link connector to no avail.
The guy I bought it from said he had the engine swapped from a non-revup to a revup so off the bat I know a lot of connections are frankensteine, however the pinouts for the obd2 port are similar to a YouTube video I watched (specifically on reflashing the ecu to get the engine to work from nonrev > rev), minus a red wire that’s missing from my obd2 port. I can post pictures of the pinouts, not an issue, but if anyone has any experience with this sort of problem, any sort of guidance would help at this point.
I tested the #4 and #16 pinouts, 0V at #16 so there could be a break in the wire somewhere between fuses and the DLC.
thanks for reading.
Old Jun 30, 2023 | 12:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Exactly what year is the car.
Are you sure they didn't go revup to non-revup? This is usually what happens because people don't want to pay 3x as much for the revup engine.
The cigarette lighter fuse is in the cabin Fuse Block - J/B, the diagnostic port fuse is IPDM fuse 89 for pin 8 and the fusible link fuse 34 for pin 16. I suspect the fusible link fuse is blown.
Pin 4 and 5 are ground so make sure they both have continuity to chassis ground.
Lil_Spanish
Jan 24, 2019 06:26 AM
dsunz
May 18, 2011 09:17 PM
zhadow04
Mar 24, 2010 07:45 AM
Ghayes23
Jul 26, 2008 09:30 PM
Xblackg35X
Apr 6, 2007 10:08 AM
