2005 g35 headlights issues?
Rating: Thread Rating: 2 votes, 1.00 average.
Old Aug 17, 2023 | 05:42 PM
Sam617's Avatar
G35
Both my headlights doesn’t work. I check all the fuses, all is fine. I switched bios around and the igniter around still doesn’t work. When I hit the high beams, I could hear it clicking around the headlights but still no lights. What could it be? Any help would be appreciated.
Old Aug 17, 2023 | 06:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did they both stop working at the same time? Did both the high beams and low beams stop working? Do any of your parking lights work? Do your brake lights work?
Is anything else in the car not functioning? Does the car start, run, and function normally except for the headlights.
Old Aug 17, 2023 | 07:08 PM
Sam617's Avatar
G35
Brake lights and Blinkings still work
Old Aug 18, 2023 | 06:18 AM
Sam617's Avatar
G35
yes
Old Aug 18, 2023 | 12:17 PM
cleric670's Avatar
BANNED!!!
Sounds like you blew a fuse, check:
Fusible link slot F
IPDM fuses 71, 78
Cabin Fuse Block - J/B fuses 1, 6, 18.
That covers all the power for the headlights, BCM, and CANBUS systems needed to communicate between the BCM and IPDM.
When you turn the switch for the headlights you're just telling the BCM to tell the IPDM via CANBUS (network) to turn on the headlights, you're not actually turning them on yourself from the headlight switch. So all three of those functions need to be working.
Old Aug 18, 2023 | 07:10 PM
Sam617's Avatar
G35
Fusible link slot F
IPDM fuses 71, 78
So where is the cabin fuse? Sorry for the stupid question.
Old Aug 18, 2023 | 07:27 PM
cleric670's Avatar
BANNED!!!
Driver footwell, there's an access panel to cabin Fuse Block - J/B
Old Aug 19, 2023 | 03:08 PM
Sam617's Avatar
G35
So I checked all my fuses and all is fine. Idk what else to do.
Old Aug 19, 2023 | 09:39 PM
cleric670's Avatar
BANNED!!!
Just to verify, you don't have high or low beams correct? And both headlights stopped working at the exact same time yes?
Old Aug 19, 2023 | 09:44 PM
Sam617's Avatar
G35
Yes
Old Aug 19, 2023 | 09:46 PM
Sam617's Avatar
G35
Fusible link slot F
IPDM fuses 71, 78
Also I don’t know what all this means
Old Aug 19, 2023 | 09:47 PM
Sam617's Avatar
G35
Sorry for being a newb
Old Aug 19, 2023 | 09:50 PM
cleric670's Avatar
BANNED!!!
Fusible link is in front of the battery, IPDM is the engine bay fuse box behind the battery, cabin Fuse Block - J/B is in the left/driver footwell.
Old Aug 21, 2023 | 04:18 PM
Sam617's Avatar
G35
Could it be my ballast igniter?
Old Aug 26, 2023 | 01:40 PM
cleric670's Avatar
BANNED!!!
I'd start by checking for power and ground at the ballast harness. Headlight grounds are located in the engine bay on the front of the wheel well.
Did you check all those other circuits I listed? And do your fog lights work or not? What about all your other parking lights?
Since both headlights went out at the same time it's very unlikely it's the ballast but verifying there's power and ground to everything is the next logical step.
Left side headlight harness.
red/yellow stripe, 12vdc for low beam
black, ground for low beam
red/black stripe, 12vdc for high beam
black/white stripe, ground for high beam
Right side headlight harness.
brown, 12vdc for low beam
red, 12vdc for high beam
Those ground wire splice together and are landed on a 1-hole lug on the front of the wheel well in the engine bay.
You have already rated this thread Rating: Thread Rating: 2 votes, 1.00 average.
