2005 sedan rear brakes sticking .. question about the caliper slide pins
Old May 11, 2024 | 07:47 PM
ninjabong's Avatar
I noticed when you take out the slide pins they are different one has a rubber bushing and one does not. does it matter which hole you put them in?
Old May 12, 2024 | 03:59 AM
Scorpi0's Avatar
If they are the same size and length then u can swap them with no issues. But one of the bolts should have a G on it and the other should have a L. Then look at your caliper and u should see a G and a L, indicating which pin goes where.
gtreanto
Apr 1, 2010 12:31 PM
ErinFaulk
Nov 6, 2006 08:39 PM
waterp7
Aug 25, 2005 10:36 PM
