G35 Sedan Rear Brake Question
Old Sep 27, 2005 | 03:40 PM
gtreanto's Avatar
I just replaced the rear brakes in my wifes 2003 G35 sedan. I took both sides apart and sent the rotors out to be turned. When I was putting the caliper back on I noticed the guidepins are different. Does anyone know if the caliper guide pin with the roller on it goes on top or bottom or does it matter?
Old Apr 1, 2010 | 01:52 AM
Drivefastjeff's Avatar
I have the same question. Does anyone know?
Old Apr 1, 2010 | 11:28 AM
brandon1978's Avatar
According to my 06 service manual, the bushing goes on the top "sliding pin bolt". Is that what you were asking? Usually when I do brakes, I loosen the top pin and remove the bottom. Then I just rotate the caliper out of the way.
Old Apr 1, 2010 | 12:31 PM
Yes I think that's what I'm talking about. There is a little plastic bushing near the tip of one of the slide pins, but I don't remember if I pulled that one from the top or bottom hole of the caliper.
Jusseth
Sep 13, 2020 12:25 PM
kinetek
Aug 3, 2015 04:25 PM
teamghost
Jul 28, 2015 04:52 PM
emorehs
Jul 17, 2015 09:45 AM
mushu
Jul 15, 2015 03:55 PM
