Help.. Window rear difroster isn't working
Old Mar 14, 2005 | 11:17 PM
Vic's Avatar
Vic
I have a 2004 G35 coupe, and recently the rear window defroster is not working. evertime the rear window got fogged up, the rear defroster does not clear it up at all. The weather is still cold here and the window got fogged up very easily.
does anyone ever experience this and how did you fix it?
Thank You.
Old Mar 14, 2005 | 11:19 PM
SilverII's Avatar
Take it to the dealer....
Is it hot/warm to the touch?
Old Mar 14, 2005 | 11:22 PM
Vic's Avatar
Vic
I never touched it.. so I have no clue..
as for now, everytime the window got fogged up, I have to turn on the A/C to the max speed and aim it to the rear window. It clears up the window, but it takes a very long time.
Old Mar 14, 2005 | 11:29 PM
Mr.GEE's Avatar
20 Year Member
Check the fuse. If it's OK check connectors in wire harness in trunk, under rear window shelf.
Old Mar 14, 2005 | 11:34 PM
Vic's Avatar
Vic
Ok, so how do you know if the fuse is OK and how do you know if the connectors are OK?
Old Mar 14, 2005 | 11:54 PM
Mr.GEE's Avatar
20 Year Member
I'm not sure what type fuses are used in the G, but my other Nissans have the clear colored fuses that when you look thru the side, you can tell it's burned open, if you can't tell, just replace the fuse. As far as the connectors, you check to see if they are plugged in and have not accidentally been disconnected.
mike730
Jan 12, 2018 04:25 PM
apintojr
Jul 23, 2015 10:52 AM
nascarbuff17
Jul 16, 2015 10:23 AM
beevanhuynh
Jul 14, 2015 09:06 AM
