Anyone ever taken off the resonator in front of the air filter?
Old Mar 15, 2005 | 06:21 PM
P_Diddy's Avatar
I just installed a Z-tube and now I'm going to install a K&N air filter.
Looking at the intake of the car, it seems pretty restricted. Has anyone ever removed the resonator (Part #8 in diagram) for more airflow into the airbox? I'm not sure if it's possibly though, it may support the air cleaner case (Part #10). Gonna check it out tonight.
Old Mar 15, 2005 | 06:28 PM
Diesel1's Avatar
Moderator
I believe peeps have removed it! Probably just makes it a lil louder that's all. Frees up a little restriction. In my eyes, the stock air intake is pretty damn good!
Old Mar 15, 2005 | 06:29 PM
1Gig's Avatar
It doesn't support the air box, and it's a pain to take out. I don't think it will provide more air since it only has a small opening to that resonator. I took it out because I put in a NISMO intake. Goodluck.
Old Mar 15, 2005 | 06:32 PM
SilverII's Avatar
Looks like removing #5 will result in a bigger opening...
Old Mar 15, 2005 | 06:35 PM
SoCalTed's Avatar
restrictions... ever noticed where the hood bumper hits the front end support?
Take a look... yes, right in front of the intake for part #5.
DaveO actually dremeled/ported out the support under #5 to allow more air.
Most of your air is coming from 7 and 5 anyway. There is a Stillen hose for the 350z that ducts in from the front lip to the bottom of the collector (#10).
-T
-t
Old Mar 15, 2005 | 06:55 PM
RussB's Avatar
more noise does not always equal more power. i've removed the silencer on some of my past cars and every single time I ended up putting it back on. i consistently noticed wierd dips in my low end powerband and funky "tip-in" without the airbox / silencer.
there was an article in SCC a while back that demonstrates this when they modified the intake on a focus, and the removal of the silencer created some turbulent airflow across the MAF sensor which caused erratic airflow readings.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
derres
Aug 28, 2015 03:27 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
