Question: Flat Torque Curve Clarifcation
Old Mar 24, 2005 | 08:07 PM
SAL9000's Avatar
Originally Posted by asianautica
So to say TQ in itself doesn't tell us anything is not true. Because when you know TQ at a certain RPM, you'll know the HP.
"Because when you know TQ at a certain RPM, you'll know the HP."
I believe this does indeed equate to "torque in and of itself means nothing". Without knowing RPM, power is indeterminant, and power (i.e., work per unit time) is what moves your car.
The integral of power with respect to time is work, which is engineering-speak equivalent of saying torque per unit time = power. In other words, HP = TQ * RPM/5250.
Old Mar 24, 2005 | 08:13 PM
SAL9000's Avatar
Originally Posted by SkylineG33
So it's best to stay in the current power band to keep the car moving? Downshifting and rev matching should take care of that right? Or am I wrong and that it puts me at the new gear's powerband? Gosh...I don't even know what I'm saying, lol...
Yes, exactly, if the downshifting will put you in a better part of the engine's power band. This is not always the case. Best way to determine power band is with your own behind. Nowadays, performance cars are generally geared fairly well with respect to power band.
Old Mar 24, 2005 | 08:23 PM
asianautica's Avatar
The integral of power with respect to time is work, which is engineering-speak equivalent of saying torque per unit time = power. In other words, HP = TQ * RPM/5252.
Well, TQ is an equation of HP and RPM so you won't know the TQ unless you know both HP and RPM. So saying "torque in and of itself means nothing" is not correct either because you won't know how much TQ the engine produce unless you know the RPM too.
And yes, that equation was in my last post.
Old Mar 24, 2005 | 11:12 PM
SkylineG33's Avatar
Thanks for the explanation asianautica! I got a better idea now, it was quite helpful...
Detailed Image
Sep 28, 2015 07:04 AM
Since 1983
Sep 19, 2015 10:26 AM
Detailed Image
Sep 11, 2015 08:37 AM
Mikesta
Audio/Video/Electronics
Sep 10, 2015 05:14 PM
