Easy question about Motordyne spacer installation
Old Mar 24, 2005 | 06:54 PM
JZ39's Avatar
How do you know where the long, medium and short bolts go?
In the diagram it appears as though there are 12 bolts around the periphery of the spacer and 6 in the middle.
Now, the kit comes with:
11 short bolts
3 medium bolts and
4 long bolts
How are these arranged? What is the make up of the 6 bolts on top of the plenum?
This might be totally obvious once I get in there, but, it never hurts to ask first.
Old Mar 24, 2005 | 07:03 PM
G352NV's Avatar
Never enough
When you pull the stock ones out you can see what ones are longer then others. The longer spacer ones go where the longer stock ones go.
Old Mar 24, 2005 | 09:13 PM
JZ39's Avatar
Thanks man.
I figured that would be the case.
Can't wait for the weekend!
Old Mar 24, 2005 | 10:11 PM
maxpower's Avatar
11 short bolts
3 medium bolts and
4 long bolts
Installing new plenum bolts:
Install all the bolts with washers finger tight. The long bolts go in 9, 3, 1 and 6. Medium bolts go into
5, 2 and 4. The short bolts go into the plenums outer perimeter. Once they are installed finger tight
and aligned, tighten all the bolts in the numerical order shown below to 5 ft-lbs torque.
Old Mar 24, 2005 | 10:30 PM
JZ39's Avatar
You da man!
Thanks for the detailed info!
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
Soumilg
Jul 18, 2015 12:33 PM
