Questions for other 6MT owners
Old May 18, 2003 | 10:06 PM
Black_Mirror's Avatar
While I was driving my new G...i noticed that during upshifts, the car slightly blips up by several hundred rpms. Anyone else notice this?
Old May 19, 2003 | 10:31 AM
Conquie's Avatar
Re: Questions for other 6MT owners
I haven't noticed that - at all.
In fact, what I have noticed is that the second I push in the clutch, the RPM's drop like a stone. Never had a concern that it might stall or anything like that, but it seems to drop off REALLY fast, like the engine is extremely loose (in a good way).
You might want to pay careful attention to what your right foot is doing... the gas pedal is fairly light, you may be goosing it a bit and not even realize it. Try shifting normally, but consciously pulling your right foot well off the gas before pushing the clutch in, see if that makes a difference.
2003 G35 Coupe 6MT Leather
Premium, Aero
"There is no spoon"
Old May 19, 2003 | 01:55 PM
RamboRami's Avatar
G35driver.com Moderator
yeah mine does the same thing Black_mirror
I have 1600 miles on the G now.
When disengaging the clutch with the foot off the gas, the rpm will increase ever so slightly, then it will drop down.
Im guessing this has to do with the drive-by-wire throttle lag as it will get better and less laggy as you continue to rack-on the miles.
<font color=green>-Leblau Timmaw</font color=green>
Old May 19, 2003 | 02:22 PM
redwillow's Avatar
20 Year Member
I've had my 6 spd a week now. I noticed that I had to stop hitting the gas so much when I shifted. Seems like I just have to barely tap it when shifting. Haven't noticed any dropping out when shifting at all.
Old May 19, 2003 | 06:26 PM
Kojo62's Avatar
No. mine doesn't do that. But I drive with the distinct habit of lifting off the throttle when pushing the clutch in, ordinarily. I agree with others, you're probably unconsciously blipping the throttle a little bit.
<font color=blue>2003 G35 Coupe 6MT - diamond graphite / graphite leather - premium - nav</font color=blue>
Old May 19, 2003 | 06:52 PM
ReDRoK8's Avatar
I think it's the drive by wire technology guys. My brother had the same problem when he drove my G. Then he got his new DG and had the same effect. I found that he wasn't letting off the gas enough when hitting the clutch. The drive by wire seems to lag a little bit so you have to let off a little sooner that a standard throttle cable. Also I did notice that the RPMs seem to drop unnaturally fast and I think this is because it's call computerized. I don't have much issue with it except when trying to "performance" down shifts it is next to impossible to give the gas pedal a "tap" to match engine speed to the clutch for a smooth down shift. Just my .02 cents gents. Peace. [img]/w3timages/icons/cool.gif[/img]
-Jason
Laser Red '03 6MT
Old May 20, 2003 | 08:24 AM
gumpdriver's Avatar
Montgomery's Finest
I had that problem this week on a trip ,,, It was only about a hour and every so often when i press the gas it would go up two or thee rps then it comes down....
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
