Mikes rearview mirror radar mount
Old Apr 4, 2005 | 02:58 AM
ChuckP's Avatar
Ive been wanting to order Mikes (from my350z.com) V1 rearview mirror mount for my G coupe. But i havnt seen any G drivers using it. I have the homelink mirror, and ive seen numerous pics of Z's with it installed on the same mirror, so i would assume it fits, can anyone confirm this, so i dont have to find out the hard way. thanks guys.
Old Apr 4, 2005 | 03:16 AM
civic4982's Avatar
could you show a link of this? I'm interested as I already have a V1 and my G comes in within the next 2 weeks.
Old Apr 4, 2005 | 03:42 AM
ChuckP's Avatar
ya.......anyone?
Attached Thumbnails Mikes rearview mirror radar mount-v1mount11.jpg   Mikes rearview mirror radar mount-v1mount22.jpg   Mikes rearview mirror radar mount-z-radar-bracket-2.jpg   Mikes rearview mirror radar mount-radar-bracket-004.jpg
Old Apr 4, 2005 | 04:24 AM
civic4982's Avatar
that looks really nice... I went coasting around my350z.com to check it out as soon as you'd mentioned it...
Old Apr 4, 2005 | 05:58 AM
shipsaeki's Avatar
does the V1 slide off from the bracket incase you wanted to take it off when ever... It looks like it would. Not so sure how tight the fitment is tho. Where can we order these... i'm pretty interested.
Old Apr 4, 2005 | 07:51 AM
Speedoholic's Avatar
G (enie) FUNK ERA
I would be very careful with mounting anything to a rearview mirror that is glued to the windshield - those tend to eventually come down overtime under heavy loads.
Old Apr 4, 2005 | 09:57 AM
Pratik's Avatar
Moderator
I've had Mike's mount for a while for the Escort. I relaly like the mod because I think its in a good location and can get a clear view of the road with the radar.
As far as it hanging on the rear view, mine was pretty solid - even with a sub cranking out some good bass never had a problem with it falling off. What I did was put a layer of masking tape around the mount that sticks into the radar (You don't actually see this) so that made it have a nice tight fit..
I actually just sold my mount to someone on the boards though because of the fact I work in Virginia (where the damn radars are illegal) and was always concerned about pulling up next to cops and them seeing it so for now I mounted it up high via the suction cups next to the rear view. If VA had them legal I would have kept my mount though. If its hardwired it looks good.
Old Apr 4, 2005 | 11:38 AM
SaltiDawg's Avatar
pratik97,
I do not know how many police cars in VA are equipped to do so, but some are able to use ECM and detect the RF emissions of your Radar Detector. Years ago I had co-worker that got pulled over at like 3:00AM in VA on the way to Dulles from MD for operating a Radar Detector. Hefty fine.
Again, I don't know how common it is for the police cars in VA to have the required equipment, but the point is that your Detector actually is transmitting at an extremely low, but detectable level.
Old Apr 4, 2005 | 11:48 AM
Deang35c6's Avatar
I think it's called "VG2" and it's basically a radar detector detector. My Cobra can detect VG2 by a distinct beep and visable display. That'll give me enough time to take it down and toss it.
Old Apr 4, 2005 | 12:05 PM
Pratik's Avatar
Moderator
Thanks for that info. I've just gotten into the habit though of as soon as I get into VA, I turn it off. I'll never keep it on - its just not worth it. However, even with it off I think they'll still ticket you if they see it in plain view (Which would happen with Mike's mount because its right underneath the mirror). With the location its at now, I dont think they can see it and with it off, they cant detect it. Is my logic correct?
Originally Posted by SaltiDawg
pratik97,
Old Apr 4, 2005 | 12:22 PM
Husker2003's Avatar
V1 Mount
ChuckP -
Mike's mount works great for the V1. I have had it for a few months now. It fits perfectly around the rear view mirror. Then, his mount screws onto one of the V1's mounts (the suction cup mount).
The only problem that I had with his mount was that it angled the V1 at a really crappy angle. I think the radar detector was basically pointed straight down. I unscrewed the metal piece from his mount and flattened it. I have heard of people applying pressure on it with their hands to do this but I guess I don't weight enough because that didnt work. So, I covered it with a rag and used a hammer. Worked out perfectly.
Then, to top the whole thing off, you should hard wire it as that is a very easy process also and looks great. I ran mine through the headliner, down the a-pillar and to the fuse box. Good luck in whatever you do.
Husker2003
Old Apr 4, 2005 | 12:52 PM
SaltiDawg's Avatar
It sounds correct. Or more correctly, I do the same thing as you. Prior to rentering VA from MD or DC I unplug and put my Radar Detector in the glove box.
Old Apr 4, 2005 | 01:22 PM
clokwork's Avatar
Cmon Son!
very cool lookin man. I likes.
Old Apr 4, 2005 | 02:53 PM
Pratik's Avatar
Moderator
Well correct me if I'm wrong but they're also illegal in DC Figures we live around the area that has the only 2 places radars arent allowed (VA and DC).
Old Apr 4, 2005 | 03:09 PM
SaltiDawg's Avatar
They used to also be illegal in CT. I believe CT at one point found that the law was not enforcible and then they subsequently changed the law. I likely am mistaken, but I thought DC was now in that old CT position - the law is not considered enforcible. (Like some state laws on things that go on in the privacy of one's bedroom. ) I'll see what I can find out - there is a seemingly authoritative www site out there that cites the law by state.
It is against Defense Department Rules to use a Radar Detector in a vehicle on a DOD base or facility. I have only seen token enforcement of this rule.
EDIT: I believe that I was mistaken about DC - every site I visited indicates that indeed Radar Detectors are illegal to operate in VA & also DC. While I no longer drive into the District very often, I have been fortunate!
