How easy is it to put the clearance lights in the Headlight?
Old Apr 16, 2005 | 10:04 PM
TheGest's Avatar
Gangster Member
So i need to take out that one bolt?
Old Apr 16, 2005 | 11:45 PM
Sickone's Avatar
I am sure someone can offer quicker - reach around methods.
I did my HIGH/Fog bulbs by the book.
- removed the wheel
- removed the plastic inner wheel well (the plastic rivets and some screws)
- then you can reach right in and change any of those bulbs
- keep in mind you don't want to touch any of the bulbs (glass part) with youtr fingers.
I did my clear corners at the same time.
Old Apr 17, 2005 | 12:01 AM
TheGest's Avatar
Gangster Member
How is that possible tho how would you put in the socket, use a cloth or what
Old Apr 17, 2005 | 12:22 AM
Sickone's Avatar
it is normally pretty easy to insert holding it by the metal butt.
The clearance Lights it is not a big issue really, I was reffering more to the Headlamps, and High/Fog Lamps
Buy it is still better to use clean latex gloves, or at a minimum wipe the bulb surface down with a clean rag and rubbing alcohol
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
wonderizm
Sep 24, 2015 03:09 AM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
