APS Plenum Is Out! GB Too!
Old Apr 20, 2005 | 11:02 AM
BrianlG35C's Avatar
Ohio G Club Member
Sharif is posting a GB price for the new APS plenum! Check it out....
APS Plenum Group Buy
Old Apr 20, 2005 | 11:08 AM
pfizzle's Avatar
any numbers? dynos? + - ?
Old Apr 20, 2005 | 02:28 PM
trebien's Avatar
I'm glad it's out and everything, and APS is a reputable company... but still would like to know testing results before I buy anything. I don't have much respect for aftermarket companies that sell a product before even being able to show dyno numbers. In the least, as part of the product development process, dynos should be available. That should be standard process as part of the development of a performance product.
Old Apr 20, 2005 | 02:38 PM
GT-Ron's Avatar
What's consensus on airflow limits of the factory fuel programming? With a drop-in filter, G-tube, headers and Y-pipe, is an ECU reflash going to be needed with the addition of this plenum to get the mixture to a reasonable point? Or is just with the addition of hi-flow cats with the above combo that might lean things out of the optimum range?
Old Apr 20, 2005 | 02:53 PM
neffster's Avatar
I'd sit this one out for a month or two. There are going to be so many people on my350z.com buy this and do independent dynos that it isn't even funny. (Those guys are much more hard core than most of us.) The truth about this product will soon be revealed and if the N/A results are 1/2 as good as the FI results, it would appear to be a pretty good buy.
One potential problem... there is a lot of speculation about the TS ECU reflash being mandatory to see any power. This means a ~$800 manifold and a ~$600 reflash for ???? power. Another "issue" is the interesting post about "lifting" on the FI dyno run. If this is the case, the N/A product might not be any better than the plenums and spacers we already have...
Only time will tell.
Old Apr 20, 2005 | 03:14 PM
GT-Ron's Avatar
If it's as good as the competition, that would be fine with me. Doesn't hurt having more viable options on the market.
And while I wasn't going to jump on this one ASAP, I agree that waiting to see some independent dyno results is a good idea. Likewise, finding out if the addition of the plenum, with common airflow mods such as header, exhaust, cats, etc., will require a reflash is a must. As I mentioned in my previous post, finding out at what point the reflash is necessary, before I get there, would be beneficial.
Old Apr 20, 2005 | 07:50 PM
Sukairain's Avatar
Neff, $800 for the intake manifold? The APS one is only $355. Don't know about the real gains but it sure looks a whole lot better than other plenum choices at this point. Whatever happened to their idea of putting in a direct NOS port?
Old Apr 20, 2005 | 08:01 PM
neffster's Avatar
Suk- This "plenum" (poor choice of words) is actually the upper and lower manifold redesigned into a straight shot deal. Have you seen the photos? It looks sick. BTW, is Suk- Japanese for Sky?
If I got one I'd have to slap a Crawford Sticker on it or else I'd be banned from the brother hood.
Old Apr 20, 2005 | 08:12 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
neff,
are you referring to the new Kinetix intake manifold or the APS plenum? I think the $800 one you're probably refering to is the Kinetix one huh?
doc
Old Apr 20, 2005 | 08:14 PM
Sukairain's Avatar
Yeah, the Kinetix seems to be what you are speaking off. If I had the money I would get the Kinetix just because it looks sick. Gain or no gain, it's quite a show piece.
Sukairain = スカイライン
Old Apr 20, 2005 | 10:31 PM
sarcasmo's Avatar
Sweet. I have quite a bit of experience with APS products and everything I've seen from them has been absolutely top notch. I'll definitely be following the info on this.
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
