My Coupe's pulling to the right..Help
Old Apr 21, 2005 | 11:14 PM
BlackM6C's Avatar
Hey guys,
I feel the car pulling too hard to the right..And it feels a little rough at high speeds for some reason?? Almost a tad unstable..?
I put new rear tires on and left the stock pilots in the front, as they are okay. I know that the tire guys did remove one front wheel to check something out...Does this mean I need an alignment or balance?
Thanks!
Mike
Old Apr 21, 2005 | 11:15 PM
S-Tuned's Avatar
gtr proto test driver
you sure you dont have a flat or something
Old Apr 21, 2005 | 11:17 PM
rs2183's Avatar
my car occasionally pulls to the right when braking only. dunno what's up with that, I read once another member was having the same problem as well with stock tires.
Old Apr 21, 2005 | 11:19 PM
BlackM6C's Avatar
Um yea, pretty sure its not flat.
Old Apr 21, 2005 | 11:30 PM
AustNMike's Avatar
you might check the inner edges of the tires....I've read on the forum that the outside can look like it has great tread, but the inner could be worn down...if they are not worn, you may have a bad compression rod....I just had mine replaced under warranty....there's a TSB out for it and an "updated" part that the dealer will install....
Old Apr 21, 2005 | 11:34 PM
BlackM6C's Avatar
Thanks Mike..I will take her in (This car is such a pain, literally!)
Old Apr 21, 2005 | 11:35 PM
BlackM6C's Avatar
Mike..What were the symptoms of the compression rod?
Old Apr 21, 2005 | 11:36 PM
rrpnow's Avatar
also, could be that ur new tires are creating more friction with the road because they are knew... and your front tries are already warned out, so maybe thats why!?!?!?
Old Apr 21, 2005 | 11:53 PM
jjyellow's Avatar
What year is your car? I had a slight pull in an 04 coupe brought to dealer and they fixed under warranty out of alignment. They told me that some 03 models had a recall where the car pulls hard to the right they have to replace one of the control arms
Old Apr 21, 2005 | 11:54 PM
BlackM6C's Avatar
its an 04..I am going to take it in
Old Apr 21, 2005 | 11:57 PM
AustNMike's Avatar
drifting/pulling to the right...you may also have a bad wheel bearing or something....check this LINK for a list of TSB's on the 03...not sure if these apply to other year models....
Old Apr 21, 2005 | 11:58 PM
BlackM6C's Avatar
thanks guys
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
will091195
Jul 27, 2015 09:19 PM
ddietz97
Jul 26, 2015 06:16 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
