Mirror garage/gate opener button
Old Apr 24, 2005 | 07:25 PM
GLuXuRy's Avatar
In the manual it says to press the two outer buttons to clear the memory. I wana set one button for my garage at my house and the other for the garage at my apartment. My question is if i press the two outer buttons to clear the memory will it erase my previous memory for button 1? Thanks in advance as some people will say
Old Apr 24, 2005 | 07:44 PM
RBull's Avatar
Rated M
I'm not sure of the answer but believe that that will erase the memory of all 3 stored buttons. I think there is a number for Homelink in the manual where they will guide you through the process and probably be able to answer your question.
Good luck.
Old Apr 25, 2005 | 04:48 AM
dropshadow's Avatar
when you program the buttons, you don't have to clear everything. i can't remember specifically, but hold the buttons down it tells you to until it starts flashing, then you press the button you want programmed along with your garage door opener. that way it only programs that one button.
Old Apr 25, 2005 | 08:10 AM
giddyup69's Avatar
if u already have one programmed then just go ahead... pick another button and do it again. no need to flash the memory again (aka hold 2 outer buttons again).
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Oregon13
Mar 1, 2016 12:06 AM
BfloG35
Oct 16, 2015 05:22 PM
the93owner
Sep 28, 2015 10:37 PM
