Aftermarket Navigation System
Old Apr 30, 2005 | 12:42 AM
absoluteG35's Avatar
Question on aftermarket Navigation systems...
Are there any Navs on the market that I can install into the console where the factory nav would have been installed? I'm envisioning one that would slide right out and turn to the programmed position. I haven't seen any posts on this nor have I seen people with pictures that show after market Navs. Would be nice to do an easy install without the heavy modification to the dash.
So far, I'm liking the Kenwood P-NAV715, Kenwood Excelon P-NAV815, and the Alpine NAV-200.
but will they fit?
Old Apr 30, 2005 | 12:47 AM
TopTech's Avatar
nope, there aren't any. don't use that handy search function either, cause it doesn't work. you are boned. buy a map. have a nice day.
Old Apr 30, 2005 | 01:24 AM
mrb's Avatar
mrb
Get the Eclipse unit, it doesn't install there but looks very nice. It looks almost factory and you can still use the steering wheel controls. GRider35c has a good thread about it, as he did this conversion. Looks very nice and he says the Nav is awesome, and I believe him. If you want anything in that stock NAV location, you should pray that god of cpu does his Digital Wheelz setups for the '05. If he goes that route, it would be a tough choice between the two for me. His setup with the Xenarc screen is killer! Only reason I've been looking at the Eclipse is because the DW isn't available
Old Apr 30, 2005 | 01:38 AM
Gee Im Fast's Avatar
Here is the thread that mrb is referring to...
https://g35driver.com/forums/g35-coupe-v35-2003-07/50313-getting-dealer-installed-navi.html
Old Apr 30, 2005 | 07:47 PM
Thanks, I'll check it out.
jilljann1
Jul 21, 2020 08:12 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Albanian122
Sep 7, 2015 07:41 PM
