My custom turbo G35
Old May 11, 2005 | 12:49 PM
TINMAN's Avatar
FINALLY someone has a custom kit on their car.
huh??? there're bunch of custom kit out there on the Gs.
What does "modified exhaust to spool a lot faster" mean?
HAHAHA..
Old May 11, 2005 | 01:57 PM
accordfreak's Avatar
I would like to see some if you could post it.
Old May 11, 2005 | 02:00 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Originally Posted by Skyhigh350gt
Thanks to Velocity Performance
3221 Skylane Dr.
Carrollton, TX 75007
972-389-9877
Fabrication Perfected by Stoney
Dude, you have to come out to Hooters off of Hulen next Monday and show us that thing! PM sent.
Old May 11, 2005 | 02:24 PM
Velocity Per.'s Avatar
I'm sure Brandon from Pure Precision will be showing his car off everywhere...
Old May 11, 2005 | 03:15 PM
TINMAN's Avatar
Tom (white35)
Kamal (Kamal34)
me (Tinman)
i believe Topsecret G and Havolin G running custom TT as well.
Speed Force Racing made about atleast 7 other Gs.they're just not on this board.
to me.custom kit is not mass production made.you order it,they make your out from scratch and you can order to be made to your spec.
Old May 11, 2005 | 03:21 PM
Tom (white35)
Kamal (Kamal34)
me (Tinman)
i dunno.. i think a few of those were modified mass produced kits. This guy had a shop make it from scratch. no pre-made stuff.. that's what I like about it.
Old May 11, 2005 | 03:24 PM
TINMAN's Avatar
ok..you win that IS the 1st custom turbo car.happy now? hehehe..
Old May 11, 2005 | 03:30 PM
Old May 11, 2005 | 04:22 PM
Skyhigh350gt's Avatar
If you look on velocitys site the lowest t04e can withstand 745.
Old May 11, 2005 | 04:27 PM
Pics
http://honda-tech.com/zerothread?id=1189398
Old May 11, 2005 | 05:54 PM
boostedls's Avatar
Any dynographs of this setup yet? I'll like to see the power band on the sc63 in a G35.
And what's the cost so far? I'm lookin into the greddy kit but would rather have a custom kit if the price is reasonable.
Old May 11, 2005 | 06:29 PM
panda007's Avatar
looks like a custom single turbo kit.
that's an interesting turbo placement... can't wait to see the results!
:thumbsup:
Old May 11, 2005 | 07:22 PM
Velocity 350z/G35 custom turbo system
Here is the low down on the package for everyone interested.
This package is base level (fully modifyable, upgradeable) system for around 400 hp. We can change anything to suite the power you are looking for now or down the road such as a larger turbo, built motor without having to redo piping.
Precision turbo (garret based, custom ported, special impeller, very efficient)
750 HP presicion intercooler (higher quality for cooler air temps, bar-plate construction, good to 750HP)
RC engineering injectors
tail blow off valve
tail wastegate (external wastegate, not internal like other kits)
clamps are all T bolt clamps( non of that crappy screw type clamps you get from autozone)
all stainless steel piping is used throughout
all tig welded (our welds are impressive!)
K&N airfilter
split second engine managment
down pipe uses V-bands
intercooler piping is routed through the engine bay instead of under the car like some other kits (no damage to piping by bottoming out, allows lowering of vehicle, much cleaner system)
manual boost controller
high boost couplers for intercooler piping.
This package is a custom one-off system made on the specific car, and is tuned for a perfect air/fuel ratio.
because this kit is a custom kit we can build to suit your needs.
other options:
larger injectors
larger turbo
fuel return line kit( because of the engine managment we use there is no real need for this unless you are going for high HP)
ECU reflash ( higher HP also)
the price of our kit installed and tuned is $7499.00
Old May 11, 2005 | 07:43 PM
G-Mann's Avatar
hmm thats really good price
Old May 27, 2005 | 05:08 PM
  #30
poop!'s Avatar
hell yeah thats a bomb diggity price id like to see better welds than thoose brandon also retuned today still very safe and concevative tune on 7psi he made 366whp and 343 tq with a 12 flat all the way across air fuel curve dyam stoney is the man
