rear axle replacement questions
Old May 14, 2005 | 06:28 PM
pointman1's Avatar
i am getting my axle replaced cause the clicking problem. is there anything i need to keep an eye out for? for instance, do i need an alignment after?
and, how long did it take? can i wait at the dealer while they do it?
Old May 15, 2005 | 11:17 AM
pointman1's Avatar
come on, i know some of you had the axle replaced.
Old May 15, 2005 | 11:35 AM
Gsedan35's Avatar
You don't need a alignment.
I know their's a TSB on this for ealier 350Z's for same clicking, does Infiniti have a TSB out on the G35? I have have had the clicking pretty bad for a while now.
Old May 15, 2005 | 12:39 PM
AustNMike's Avatar
There is a rebuild kit the dealer will install....I had it done 32.5k miles no questions asked....told them about clicking, called me later that day and said they had to order the kit, so you probably can't wait while they do it unless you bring it back when the parts get there, but even then it would probably take several hours...mine took 3 days including ordering/receiving parts, but I had it there for several more warranty items....not sure if there's a TSB, but they'll fix it under warranty....and yeah, no alignment necessary.....problem solved, no complaints....
Old May 15, 2005 | 01:12 PM
dubs's Avatar
Since I only had 5K of mileage on my car, the dealer installed a whole new rear.
Old May 15, 2005 | 05:23 PM
sushmaster_g35's Avatar
can someone explain this clicking problem or maybe a link to something about it??
for a while i have had the most annoying clicking noise wenever i accelerate or decelerate, it makes a few clik clik cliks...
can someone please tell me if this is the same problem?
Old May 15, 2005 | 05:58 PM
pointman1's Avatar
yeah they already ordered the new parts. just need to install them now. thanks for letting me know. appreciate it.
pointman1's Avatar
yup, thats the noise.
Old May 15, 2005 | 05:59 PM
pointman1's Avatar
thanks.
i am not sure about a tsb...but all the dealers know about it. its real common.
Old May 15, 2005 | 10:12 PM
limeg35's Avatar
this is what dealer done...quoting form work order..."Found rear axle splines dry and making tick noise, removed axle nut push axle back to lube splines, road test ok now."
Old May 15, 2005 | 11:23 PM
silvsurf's Avatar
Had mine supposedly replaced as well...yet I still have the clicking noise
Old May 15, 2005 | 11:33 PM
g35doc's Avatar
Had the rear axle on my G lubricated. No need for a replacement.
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
socalg35x
Jul 28, 2015 10:42 AM
nascarbuff17
Jul 16, 2015 10:23 AM
