warming up the car ?
Old May 18, 2005 | 03:48 PM
player's Avatar
hey guys,
do you warm your cars up in the mornings before driving it or not? (waiting til it drops to 0.5k rpm)
took me like 10mins this morning
Old May 18, 2005 | 03:58 PM
IS300TOG35's Avatar
► Matt ◄
depends on the temp outside. If its under 50 ill start it and let it warm for 10 mins. If over 50 ill baby it for the first 10-15 mins. The MT tranny is a bi^ch to shift when its cold anyways.
Old May 18, 2005 | 04:05 PM
player's Avatar
i think it as like 60 this morning in jersey
btw my car has been making weird sounds after i turn the ignition for the past 2 days, if it happens tomorrow as well, ill have the dealer look at it
Old May 18, 2005 | 04:08 PM
Sandman's Avatar
Nope. I just start it up and drive, but take it easy until the temperature needle is up to normal. I've read that by idling to warm up, all you're doing is wasting fuel and time -- you won't harm you engine and it'll get up to temp faster being driven gently. I've also heard that some the ECU for some engines (the Northstar for one, I think) actually lowers the shift points and rev limiter until the oil reaches proper temperature, but I have no idea if ours does that.
All that being said, here's what the manual says (page 5-9):
4. Warm-up
Allow the engine to idle for at least 30 seconds after starting. Do not race the engine while warming it up. Drive at moderate speed for a short distance first, especially in cold weather. In cold weather, keep the engine running for a minimum of 2 - 3 minutes before shutting it off. Starting and stopping the engine over a short period of time may make the vehicle more difficult to start.
Old May 18, 2005 | 04:13 PM
God|ZIlla168's Avatar
It depends, for could weather you should warm the car till 1000 rpm once that needle hits the one you are good to go or watch the temp gague once the needle is lined up to the end indicator line you are good to go.
Old May 18, 2005 | 04:33 PM
GT-Ron's Avatar
Most mechanics will tell you that today's engines (computer-controlled start-up maps, etc.) don't need to warm up.
With that said, I can only find beneficial things resulting from a short warm up period to allow some circulation of fluids and lubricants. The Manual's suggestion sounds hard to argue with.
Old May 18, 2005 | 04:40 PM
kenchan's Avatar
Just drive the car gently until the water temp guage starts to move.
You don't need to 'warm up' the car on these modern cars unless you
are close to the automotive storage/operational temp limits..which are
typically: -40C and +85C
Old May 18, 2005 | 04:49 PM
Infinite1's Avatar
20 Year Member
Well as a good rule of thumb i just warm it until 800rpm....then i drive slowly....till the temp gauge is normal..
Old May 18, 2005 | 04:50 PM
Jtrain's Avatar
I normally give the car a little gas 1500 or 1800 rpms untill the Temp meter hits the actual line of C, then I have a 1/2 mile 30mile zone to get out of my neighborhood, then i drive niicely for a nice mile in a 45mph zone, then I drove her i like stole her.
I warm it up and give it time, to make sure the electical stuff, lube and everything is nice and sweet...incase i have to take down anymore stock Mustangs who think they're hot with those damn flomasters
Old May 18, 2005 | 05:17 PM
player's Avatar
giving gas 1500-1800 standing or moving?
Old May 18, 2005 | 06:21 PM
JDM 350GT's Avatar
if its standing - wow you are @#$%ing up your car
moving - o_O whats the point of saying that? lol
unless you are crazy, keep rpms low.
mine sits in the garage so i give at least a min break.
Old May 18, 2005 | 06:39 PM
blazinZ's Avatar
i always give it at least 5 min to warm up, no matter what the temp.
Old May 18, 2005 | 07:13 PM
AustNMike's Avatar
I wait until the temp needle rises to the bottom line (usually about 5 minutes), then take it easy for the first mile or two....
Old May 18, 2005 | 07:59 PM
heeb's Avatar
Some of you guys are way too conservative.
Unless its very cold out, there is no real reason to let it warm up for more than a minute or so, or even 30 seconds for that matter.. and if it is very cold out, no more than a few minutes. Even that is being conservative. As long as you drive slowly, and wait for the temperature gauge to reach operating temperatures before stepping on it, you are fine. In the mornings before I leave, I routinely go out, start the car, run in and brush my teeth and then be on my way.
Only problem I see is when people start their cars, and slam right on the gas without letting it warm up for even a second. Even when its 30° out. I'd say atleast let it warm up for 30 seconds before pulling away.
