Transmission
Old May 20, 2005 | 11:28 PM
Glex25's Avatar
Administrator
Question Transmission
Let me ask you guys something about the transmission. When you guys test drove the G35 at the dealer did you feel that the gears are kinda short between 1,2,3? I'm not going to compare this car to a accord cause there is none but in the accord i could usually pull 2nd gear to 30-40mph but when i test drove the G it bucked when i shifted from 3rd to 2nd gear right before i was going to take a curve. What mph are the proper shift points for 1,2,3?
Old May 21, 2005 | 12:21 AM
GRider35c's Avatar
did u rev-match?
i can get to 60mph in second gear... the best is when im cruising at 40-45mph in 5th gear and i downshift to 2nd... the car takes off like a rocket!
Old May 21, 2005 | 12:23 AM
Glex25's Avatar
Administrator
Originally Posted by GRider35c
did u rev-match?
I think they had it rev limited since i seen the REV light on in the dash and i asked the salesperson. would that be the cause of it?
i was just slowing down and then downshifted
Old May 21, 2005 | 12:28 AM
Finiti35's Avatar
FGC South Florida BOD
Well the Accord is a 5spd, longer gears, of course you can take 2nd to 30-40 mph. I usually shift into 2nd at ~15mph or so, 3rd at 25-30 and 4th at 40.. that's being VERY conservative and shifting between 2.5-3k rpm... like he said you need to rev-match, otherwise even with proper timing it won't be smooth.
Old May 21, 2005 | 12:35 AM
Glex25's Avatar
Administrator
thats what i was thinking since these is a 6speed that the gears would be closer just wanted to make sure. ill take it easy until i get use to it
Old May 21, 2005 | 12:43 AM
GRider35c's Avatar
that red light is an adjustable shift light, not a rev limiter...
plus, the car is still brand new
Old May 21, 2005 | 12:54 AM
Glex25's Avatar
Administrator
ok that was my first time driving the G. I will keep note about rev matching since i will be driving one daily come next friday . i will break in slow not passing 4k RPM until maybe 800-1k miles. This is the first time i buy a new car so i will have to learn not to unleash it from the get.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
