Air Con heating instead of cooling
Old May 25, 2005 | 08:41 PM
Eddie23's Avatar
I need your help guys. Just got my car from the DVD and navigation conversion and the a/c is going crazy on me. If I set anything but the lowest temperature it blows heat it my face, and I mean HEAT! For example the outside temp is 25C and if I want anything above 18C inside, heat is blowing out my vents instead of cool air. Has anybody had a similar situation. Could sth go wrong when the dash was being taken apart? The inner temperature sensor?
Old May 25, 2005 | 10:46 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
#1. in-vehicle sensor wire harness loose or disconnected (located inside the panel located under the steering wheel)
More likely....
#2. AC plug harness not reconnected properly.....
doc
Old May 26, 2005 | 02:18 AM
Eddie23's Avatar
Many thanks for the prompt reply doc. Will I reach the no.1 just by taking the panels under the steering wheel off?
And where is the AC plug harness?
Old May 26, 2005 | 03:31 AM
GRider35c's Avatar
u gotta take apart your whole interior!
ok, first go under your steering wheel, u see that tiny little vent on the right, is the tube placed back on that vent?? and is the wire connected? check it!
if it is, then your A/C isnt plugged back on, remove your new headunit and check the A/C harness...
Old May 26, 2005 | 03:59 AM
Eddie23's Avatar
thanks guys, going to check it right away. And later I'll take care of hurting the guy who was doing the conversion
Old May 26, 2005 | 12:53 PM
docron1's Avatar
This is the most common problem after DD conversion.
What I have found is to avoid having to disassemble your entire dash to check the AC harness behind the HVAC unit for AC malfunctioning:
1.Check your AC functioning BEFORE you put your HVAC unit back in, diagnose and fix any problems.
2. Push and relocate your AC plug harness from behind the HVAC unit into the space behind the panel that contains the 12V power source on the passenger side. IF you relocate it there, you only have to remove a few panels to check your AC plug and not have to disassemble the entire dash....
doc
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
