Stock Air Intake Tube Inner Diameter vs. Z Tube Inner Diameter
Old May 26, 2005 | 05:38 PM
G35UKY's Avatar
Question Stock Air Intake Tube Inner Diameter vs. Z Tube Inner Diameter
Does anyone with the Z Tube know if there is a difference between the inner diameter of the stock tube versus the Z tube? I did a search because I thought this was covered somewhere, but I couldn't find it. I am thinking the Z Tube is slightly larger in diameter for increased air flow.
Old May 26, 2005 | 05:50 PM
klwoods's Avatar
99% sure that the Z-tube is same diameter...that is why it's a dirrect fit. If the diameter was different you would have to use adapters and stuff (which you don't). The z-tube simply takes out the resonator and makes the flow of air smoother allowing better flow.
Old May 27, 2005 | 10:25 AM
G35UKY's Avatar
Does anyone know if you can just "gut" the stock tube and achieve the same results? Remove the resonator(s) and put aluminum tape or something over the holes that lead into the reservoirs below the air filter and midway of the tube. I am trying to avoid losing the par tof the stock tube that belnds it in with the plastic engine cover. I like stealth mods!
Old May 27, 2005 | 10:46 AM
SilverII's Avatar
I see no harm in trying.... just have an oem z tube on hand just incase....
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
Gip
Aug 24, 2015 05:31 PM
underworld
Aug 6, 2015 01:36 PM
paniaguag35
Jul 29, 2015 12:05 PM
