6th gear grinding! HELP
Old May 28, 2005 | 02:11 AM
chester's Avatar
i red lined in 3rd and put it in neutral and rev match still grinds.. hope that explains a little bit more things..
Old May 28, 2005 | 02:15 AM
ZeroGen's Avatar
Omega Enthusiast
Why don't you shift in order: 3rd to 4th to 5th to 6th?
Seems to me an easy thing to do.
Old May 28, 2005 | 05:04 AM
DanielEshaghian's Avatar
Originally Posted by Klumzyee
theres nothing wrong with shifting 3rd to 6th O.o.. what the hell are u guys talking about lol.. u can do 2 to 6 for all the car cares..
1st of all lets say hes at 6k RPM at 3rd gear..
Clutch +
Shift to N
unclutch..
*RPM DROPS*
*rev match*
Clutch
Shift to 6
clutch..
or lets just say he waits for the RPM to set to the right level.. blip it a lil with the throttle and sets 6th in.. from what i'm reading thats what hes doing.. if you guys are saying that is wrong then "shifting" in general is wrong
Agreed...and yes, I have an 05 6MT...
Old May 28, 2005 | 06:13 AM
EricIsKlumzyee's Avatar
take it to the dealer.. obviously something is wrong.. they should be able to fix it for you with out a problem =). (i think u've already taken it to the dealer O.o and its being fixed, am i right?)
as to what caused it, i'm not sure.. could be a few things.. you can ask your service manager what was wrong when you pick it up.
keep us posted
your telling me that you will go through 4th and 5th just to get to 6th O.o? what if you were curising at 6th gear at eh lets say 50mph.. then all of the sudden a truck pulls out into ur lane. you have A. hit the brakes & slow down or B. give it some gas to pass the car next to u and change lanes..
lets say you choose B and u downshift to 3rd and merge onto the other lane.. now your in 3rd gear around 5,500 RPM.. you would go to 4th, 5th, then 6th O.o? why not just disengage the clutch and shift to the desire gear or double clutch into N and into (lets use 6th) 6th gear after the RPM sets to the correct level.. I personally would let it set lower then the point and blip the throttle a lil bit.. i prefer engaging the clutch while the RPMs are going up instead of down.. gets rid of that "blog" that ur passenger feels.
Old May 28, 2005 | 12:48 PM
kenchan's Avatar
are you clutching out while in N?
I say just shift up in sequence.
Old May 28, 2005 | 05:58 PM
ZeroGen's Avatar
Omega Enthusiast
1) Yes, I'll say it again - I would go 3rd, 4th, 5th, and then to 6th.
2) I wouldn't be cruising at 50 mph in 6th. I would typically be in either 4th or maybe 5th. Also, I'm aware of the lanes beside me and would see a truck pull into my lane.
3) If a car pulled into my lane, I would downshift and then work my way up the gears again. See my first reply.
Old May 29, 2005 | 04:03 AM
weirdo..
lol jpjp.. anyways even if he wasnt rev matching his car shouldnt grind gears.. its not his driving.. its something wrong with his tranny
Old May 30, 2005 | 09:58 AM
GMike's Avatar
6th gear grind
Chester,
I had the same problem at approx 12K miles (~ 6k miles ago). Dealer replaced the transmission w/o any question. Started out doing it occasionally, unless Ishifted very slowly. Within 1-2 days I could replicate on demand. Diagonsis was a bad syncro.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
