dropped a socket while installing ztube
hey guys. while installing my k&n filter and ztube, i accidently dropped a socket and it fell right at the top right corner of the air filter box. it didnt fall through to the floor and i cant locate it with a flashlight either. my question is, will the socket eventually fall out on its own when i'm driving or do i need to worry about this and locate it before i drive? Thanks.
-Allen
-Allen
does the box lead to the engine? If so I'd take everything apart and get it out. Nothing like a socket in your engine to mess up your day
If it doesn't lead to moving components then I wouldn't worry about it
Hooman
Hooman
ok i got that sucker out. I don't even know how to describe the place it landed but it was only about 8-10 inches down. It was in a really tight spot and I took out the airbox and was able to get it out.
Originally Posted by achen
I don't think it leads to the engine. If you face the car from the front, it fell to the right of the airbox (the area on top of the right wheel). I don't know what's down there
Fairly easy job. Take the wheel off first then release the plastic mounting pins under the liner.
C.
