Is the front fender of the G35 exactly the same as the front for the?
Old May 29, 2005 | 12:12 AM
dennis_said's Avatar
For the 350Z?
I am asking because I'm concerned about the interior fender rubbing/cracking/ruining! of my G35... I just purchased some 19x9 SSRs w/ 255/40/19 tires at the front... the guy who ran them had them on a 350Z... he said he had NO issues whatsoever w/ rubs up front...
I just put them on my G35 to take a look, and it looks like there's very little space for the axle to turn w/o the tire rubbing against the inside of the fender...
Is it just my imagination (I'm used to 18'' stocks)... ? Will this be okay?
Old May 29, 2005 | 02:54 AM
borahatch's Avatar
I do believe you should be ok. I have 245/35/20s up front and I have no issues.
Old May 29, 2005 | 03:01 AM
n1cK's Avatar
G35 6MT
it depends on how low you are. if you're slammed or pancaked down to the floor, the 255's may rub. if you have a conservative height (say not more than 1.5in), then you should be ok.
Old May 29, 2005 | 03:34 AM
Is stock height considered conservative?
Old May 29, 2005 | 06:48 AM
infinititurbo's Avatar
Sounds conservative to me
Old May 29, 2005 | 11:59 AM
Hah, nice, the width of the front tires tho at 40 make it look like the car has been dropped
Old May 29, 2005 | 12:38 PM
kenchan's Avatar
6969 had to get the kintetics because it would rub running 255's.
If they do rub, you should change them to 245/35/19's up front.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
bickfordbft
Jul 20, 2015 07:57 PM
