Driver seat discomfort?? The free 20 min solution...
Old May 30, 2005 | 01:33 AM
BlackM6C's Avatar
Hey guys,
So, I had my coupe driver seat in the basement and I was doing a little tampering....I found a simple solution to removing the bracket and relocating the controls.
After removing the control box, you can simply slide it under the padding and under the seat to the front plastic part of the seat. You can really just stick the controls wherever you want, the wires are long enough. I put them directly under the front of the seat (fastened under the black plastic)..No cutting, or playing with wires at all. Just pull it through the bottom and fasten somewhere…simple.
I then sawed the control frame off and voila...A soft bolster with no metal or controls.. Now all that must be done is to have a small piece of black leather sewed onto where the controls where.. It will look like nothing was ever there.
1) Unscrew the black seat control box on the seat..(there are two screws under small indents in plastic.You cant miss them)
2) Remove controller from bracket and slide under foam padding into the bottom of the seat.. Place controls where best suited.
3) Bend or remove metal control bracket...
The rest is just aesthetics..
Old May 30, 2005 | 01:41 AM
Jtrain's Avatar
Or lose weight
Old May 30, 2005 | 02:36 AM
BlackM6C's Avatar
Your Obviously not in tune with the problem this seat has caused for so many drivers.
Weight is not the issue..I am 6 feet, 190 pnds.
Anyway, enjoy your automatic sedan.
Old May 30, 2005 | 04:16 AM
ChuckP's Avatar
haha, fools love to flame, hes got a coupe btw, leave him alone...
Old May 30, 2005 | 04:43 AM
DanielEshaghian's Avatar
Originally Posted by Jtrain
Or lose weight
hahahahaha!!!!!!!!!!
Old May 30, 2005 | 06:23 AM
JZ39's Avatar
Yet another example of the incredible lack of maturity on this site.
What a shame.
Old May 30, 2005 | 08:36 AM
Asianicboi's Avatar
What a shame.
I agree
Old May 30, 2005 | 08:38 AM
G35Stealth's Avatar
Can you post pics of the process, or at the very least, the final product?
Old May 30, 2005 | 09:15 AM
kenchan's Avatar
Does this pertain only to the 03's? My 04 does not seem to have this problem.
Old May 30, 2005 | 11:10 AM
benbo5's Avatar
The seats are very comfortable, I can see someone having meatier legs would have a problem with the controls hitting them. So maybe the gym would be a solution to the problem. Using those leg machines work out pretty well. Then you wouldnt have to take the seat apart.
Old May 30, 2005 | 12:37 PM
BlackM6C's Avatar
WOW, you people are idiots (not all, just most) See..thats the problem on boards like this..You get people who have their G35 whatever and they know NOTHING about the car or any other car..Leaving them only to make stupid and useless comments..
Once again for you people who took the short bus in primary school..Its not a fat body issue..And if you cant realize that then please shut the F$$K up!
Old May 30, 2005 | 12:38 PM
BlackM6C's Avatar
My coupe is 04 and I had the issue.. I will post pics eventually..
Old May 30, 2005 | 03:29 PM
MrCynical's Avatar
What a shame.
Oh good lord like thats even immature . What are you 70 or something.
Old May 30, 2005 | 03:39 PM
GurgenPB's Avatar
I'm with you M6C.. thanks for you post/contribution.
The response to the original post in this thread and some ofthe responses that followed pretty much sums up the reason why many vets of this board (relatively speaking) such as myself (and I am 29) pretty much stopped posting for the most part... At some point you just get fed up...
Old May 30, 2005 | 04:26 PM
BlackM6C's Avatar
I agree Gurgen...It sucks to see a quality board deteriorate..But since any jag off can buy a G35 (or not) and post here...sucks bad.
