dealer found out i have nitrouse
Old Jun 2, 2005 | 04:15 PM
megamikedv2's Avatar
dealer found out i have nitrouse.....im screwed.... cylinders 1 and 2 supposably are only compressing to 90lbs and their supposed to be at 140lbs i think their trying to screw me over cuz their pushing me to put in a new long block which is going to run about $10,000
Old Jun 2, 2005 | 04:17 PM
coupin827's Avatar
What's nitrouse?
Old Jun 2, 2005 | 04:21 PM
tony's Avatar
you didnt expect them to honor the engine warranty after spraying did you? What is the car doing? And for $10 grand you could get a fully built engine, they'd screw you over at that price.
Old Jun 2, 2005 | 04:25 PM
mr pink's Avatar
Do you think you are being screwed over because of the price or becuase they aren't going to warranty the repair?
Seems pretty ballsy to me to expect Infiniti to cover anything with your list of mods.
Old Jun 2, 2005 | 04:34 PM
Msedanman's Avatar
O.F. Administrator
Check around for a reconditioned L/block. There are people around with spare engines. I know Malx has one or 2 sitting around.
$10k sounds about double what it should cost.
C.
GeeWillikers's Avatar
Walking The Fine Line...
Is there a such thing as an 04 Limited Edition 6MT? I'm referring to your MOD list. What makes your G a Limited Edition? I've never heard of that model before.
After what you're saying here, maybe you should call it a G35 6MT Limited Compression.
How do you think they are ripping you off? Because of their recommendation, their willingness (or unwillingness) to cover your discrepancy, or because of the price they want to charge?
Engine + labor to attach accessories + labor to install + warranty = large dollars. You may be able to get a motor from a junkyard or online cheaper, but you still have to hang it. If you don't have the facilities or ability to do it yourself, make a reservation in the hurt locker.
What is your car doing that caused you to take it in?
Old Jun 2, 2005 | 04:41 PM
waijai's Avatar
i.love.gold
That really sucks, I would try to get a quote from another place.
Old Jun 2, 2005 | 04:59 PM
poop!'s Avatar
**** it for 10,000 you could build it and boost it
Old Jun 2, 2005 | 06:07 PM
DannoG35's Avatar
WHy would it be the block. Wouldn't it be the rings? Re build it your self and put a stroker kit in. That might solve the probelms.
Old Jun 2, 2005 | 09:38 PM
TRDNiteLife's Avatar
Why the hell would you put a 100 shot on a G35...? ANYWAYS, wet or dry?
Old Jun 2, 2005 | 10:14 PM
TheGest's Avatar
Gangster Member
did you remove the nitrous when you brought back to the dealership
Old Jun 2, 2005 | 11:45 PM
zimbo's Avatar
Tell them you'll provide the long block. You can buy a lightly used one from a salvage yard for $1800. I know because I did it. Go to www.robbinsautoparts.net and search for any of the compatible long blocks (350z, G35 sedan/coupe).
Better yet, find a competent mechanic and let them do the swap. The dealer will charge $95/hour and charge you book rate.
--Steve
Old Jun 3, 2005 | 12:23 AM
Hooman6MT's Avatar
20 Year Member
NAWS!!! We on earth would you be pushing a 100 shot on this engine? Great way to screw an engine. If I was the dealer, I wouldn't give you an ounce of sympathy. Congrats on your new paperwieght!
Hooman
Old Jun 3, 2005 | 12:59 AM
RussB's Avatar
as far as warranty, what did you expect? anything less than paying for the repairs out of pocket would be fraud.
so two of your pistons have low compression... it could be any number of things, most likely rings or cracked piston. those don't necessarily require a new block.
