Z-tube ** Fix **
Old Jun 8, 2005 | 01:43 AM
Derek S's Avatar
Z-tube ** Fix **
hay guys how do i FIX the Z-TUBE problem. the one ware it rubs against the A/C line. i instaled my z tube and pop charger and now the little plug for the sensor is pushing against the A/C line. its to a point that the A/C line is pressed down.
Old Jun 8, 2005 | 01:56 AM
vstypicals's Avatar
Pull the AC line as far away from the ztube as possible using zip ties.. and you can also wrap the AC line with split flex tube or some sort of foam that are meant to cover electric wires. These can be found at any hardware store. I got mine from Ace Hardware.
I hope that helps. Goodluck.
Old Jun 8, 2005 | 08:17 AM
tha_kid's Avatar
You can bend the bracket too - tht's what i did
Old Jun 8, 2005 | 11:06 AM
crypten's Avatar
Here is how I fixed this issue.
https://g35driver.com/forums/showpos...24&postcount=6
Old Jun 8, 2005 | 11:45 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
I hope you got this issue resolved. and enjoy the ride~~~
Old Jun 9, 2005 | 12:39 AM
Derek S's Avatar
thanx for the help Gene ill try that. i went and bought all the stuff today and ill put it on tom i even got some spacers and put them on and it lifted the pop charge a little helped alot. THANX
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
