Owners of '05 6MT's, having installed Gordgee's GroundingGear . . . What are your thoughts and/or comments after your installation?
I've logged just a bit over 1K miles on my G and just installed a Z Tube, last night. I am thinking about installing the said wires. I've searched throughout the threads with regard to Gordgee's GG kit. However, most of the positive comments are from AT owners . . . And as such, I am curious to what you '05 6MT owners have to say.
What are the improvements to your G, if any? Any comments and suggestions would be appreciated. Thanks in advance.
i'm interested in what 6MT owners have to say too. b/c i was also thinking about these grounding kits
me too. sorry to jack ur post kinda, but is there any difference between gordgee's gg and ones from Sun Auto?
Quote:
I read G owners were happier after having switched their grounding wires to Gordgee's. Sun Auto was one of the kits mentioned, among others. As I mentioned in my earlier post, most of the owners were AT owners. It seems that first and foremost the grounding kits improve on the shift lag on AT's.Originally Posted by supag116
I didn't see much with regard to 6MT's, which is what I am interested in, especially with comments directed towards '05 6MT's.
Quote:
PM GordgeeOriginally Posted by rrpnow
where do you buy it at?!?!?
I've heard grounding kits are really a big help to ATs and not so much to MTs...One of my fellow G driver friends told me it helps with the shifting while using Tiptronic...That's just me though...do some more research and let us all know...
I just installed The 6MT Performance System full 8 wire package (6, +1, ECU)
on my 05 6mt coupe. I installed the kit without the ecu wire at first and did notice an improvement at idle. It wasn't until I installed the ecu wire and did a ecu reset when I noticed a definite improvement in throttle response, just like others said, it seemed to wake the car up. Not too dificult to install, instructions are simple and clear.
I've had the 8-wire kit on my '05 6MT for a couple of months now. Like the above poster, I didn't notice much of a difference with the initial engine wires. After I installed the ECU wire, the car seemed to smooth out a bit, maybe some better throttle response.
Kind of a toss-up on whether to do it again; I really should disconnect the wires for a while to get a better idea.
Thanks to wood_man and Darth_Bobo for sharing their thoughts and comments with regard to the GroundingGear Kit.
This is one of the mods, which I am thinking about. I'll probably proceed with it in the near future. I'll be sure to post my comments, as well.
Thanks, again!
Thanks, again!
Anyone know how i can get in touch w/ Gordgee? I'm not a paying member so I can't PM... I would like to get his grounding kit.
Thanks.
Thanks.
You don't need to be a premier member to PM. You do need to have a minimum 5 posts and you have only 4. Just post another message....then wait an hour or two and the system will recognize you have 5 posts and allow you to use PM.
