govern limit...smog?
ive been reading on thier site, but I wanted to ask the guys who actaully use it...Does it void the warrenty or cause any sort of drop in MPG ??
I would also like to know the answer to what the top speed is if the governor is removed.
Not too interested in the rev limiter removal since i know i would probably blow the motor.
It does not remove the rev limit, it changes to a slightly higher yet safe rev limit so you can squeeze a lil more hp/tq out of the VQ35.
If inifinity hooks up the consult they can tell that you've altered the ECU image. Void your warranty is possible but you could also play ignorant to the fact, but if they reflash it, bye bye technosquare chgs + the price you paid for the initial flash.
