Coolant question
Old Jun 19, 2005 | 11:03 AM
s14roller's Avatar
Coolant question
Hey guys, I'm just wondering if anyone has used the green prestone coolant to top off their coolant tanks. I'd imagine it's the same as the nissan coolant but I'm not sure and the Infiniti dealer near me is closed right now. Any help would be appreciated.
Old Jun 19, 2005 | 11:54 AM
g35pat's Avatar
If I were you, I wouldn't take a chance and add Distilled Water until you can take it to the dealer to have it checked. In fact, if it isn't that low, I would just wait.
Old Jun 19, 2005 | 01:03 PM
kenchan's Avatar
Some of those off-the-shelf coolants eat away at aluminum blocks.
If it says it's for aluminum motors it might be okay, but as above
just go to the dealer and buy a bottle; do a 50/50 with distilled
water and you're set.
Old Jun 19, 2005 | 01:36 PM
Msedanman's Avatar
O.F. Administrator
I'm sure it's the same. Just don't mix colours. (ie- the longlife red coolant).
C.
Old Jun 19, 2005 | 02:53 PM
s14roller's Avatar
Thanks for the replys guys.
Old Jun 19, 2005 | 03:12 PM
lucidazn's Avatar
C.
Is red better than green?
Which has more acidic properties?
Old Jun 20, 2005 | 10:48 PM
chinee's Avatar
Do not add coolant to top off your cooling system. If it's low, it's likely that only the water has evaporated... coolant typically doesn't. So to maintain the same ratio... top off with distilled water only.
If there's a leak, then you can top off with a 50/50 mix and get your G to a garage for a thorough inspection. If they need to repair, they drain the cooling anyway and refill it accordingly.
Old Jun 20, 2005 | 10:51 PM
636Racer's Avatar
RM125, google it.
baker2795
Sep 2, 2015 06:00 PM
Blakearold
Aug 27, 2015 12:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
