Help: Trunk only opens using key fob
Old Jun 19, 2005 | 12:56 PM
DrPJM1's Avatar
As stated: Trunk only opens using key fob, the interior button for the trunk release does not work. Any hints, suggestions, solution?
Old Jun 19, 2005 | 01:11 PM
redwillow's Avatar
20 Year Member
there is a valet switch visable when you open the glove box. It disables the interior trunk release switch...check that.
Old Jun 19, 2005 | 01:56 PM
realgone's Avatar
Widdle ya into kindling
WOW, thanks for the info. I never new about the switch. My Jetta had a safety feature for the trunk swith and I was dissappointed that the G did not have this safety feature. But, I guess it does.
Old Jun 19, 2005 | 02:00 PM
GRider35c's Avatar
my trunk doesnt open with the remote or the switch like 10% of the time, i have to turn the ignition on then off, then it works fine...
anyone else have this issue, mine is an 05 coupe 6mt
Old Jun 19, 2005 | 02:07 PM
Msedanman's Avatar
O.F. Administrator
Could be an issue with the BCM. Have the dealer check it for you.
C.
eljefe7070g35
Sep 11, 2015 09:28 AM
douglas555
Sep 10, 2015 04:48 PM
Albanian122
Sep 7, 2015 07:41 PM
