Best way to take off center aluminum trim around 5at shift knob.on the 2005???
Old Jun 21, 2005 | 12:59 AM
g35driver05's Avatar
Best way to take off center aluminum trim around 5at shift ****.on the 2005???
Hi, im planning on installing my Pac-AAI-NIS unit in sometime this week. I was wondering what the best way to remove the aluminum trim is?
I have the manuel on cd and know where the fastners are etc.. but just wanted tips on how to remove the trim wit out scratchign it. Once its removed the rest should be cake..
THanks!
BTW.. what are the three extra wires on teh PAC.. the Blue(red striped)/yellow/and Blue(yellow striped)
Old Jun 21, 2005 | 01:14 AM
dwoloz's Avatar
Personally, if you want to guarantee you wont scratch anything mask it all off with masking tape
it may leave a little residue after you take it off but nothing some goo gone cant handle and it sure is better than having scratches
I cant say on how to do it for the 05 since I have an 04 but with 04s and 03s you remove the lower plastic pieces for the passenger and drivers side, then remove the lower center console to reveal the screws holding in the whole stereo and hvac unit
The extra wires on the PAC unit are for interfacing with the SWI-X unit, dont worry about them
Old Jun 21, 2005 | 02:27 AM
gizsf's Avatar
Use towels also.
Old Jun 21, 2005 | 10:52 AM
I was able to remove ALL BUT the 2 last clips that hold it in place near the ash tray. I sturggled with it for while then just gave up . I checked the repair manuel and it only shows 2 clips near the ashtray area. But i was not able to disingage them. Anyone know a nice trick? I tried pulling it towards the back.. stright up . but nuttin. The all the other clips came of very eazy jsut these 2. are hard.
Thanks.
Old Jun 21, 2005 | 11:26 AM
TwiBlue's Avatar
where do you plan on placing this PAC AAI NIS?
Old Jun 22, 2005 | 09:48 AM
anyone?
Old Jun 22, 2005 | 10:08 AM
robnick2's Avatar
If your car is in park, you can't pull the aluminum piece out. Put on the emergency brake and then put the car in neutral then you should be able to get it out.
I just installed my PAC yesterday. I can't get my shifter **** working. Can anyone offer any help on this?
Old Jun 22, 2005 | 10:26 AM
BlackonBlackG35's Avatar
The shifter was the biggest pain in the A$$!! I didnt figure it to put into neutral for a while...I just used a flat screwdriver...not a single scratch.
Old Jun 22, 2005 | 08:29 PM
Thanks alot guys! I will try to out tomm. The manuel didnt' say put it in Neutral.. I had the whole thing lifted it was just the 2 clips near the ash tray that i coulnt' get off.
Thanks
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
b2autodesigns
Accessories-Vendor
84
Jun 20, 2017 04:38 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
