Installed FX Shifter in Coupe
Old Jun 15, 2003 | 05:00 PM
35C's Avatar
35C
I ordered the shifter and installed it.Took a few hours.This is the shifter they should have put in the coupe.I dont recommend doing this as there is lots of trial and error cutting and shaving of the shifter,and plastic plunger that engages the button.Not enough and it wont go into park,too much and it could get knocked into reverse or park easily.See attached pic
g35 coupe black/auto/fully equipt
Old Jun 15, 2003 | 06:14 PM
deadmanincbh's Avatar
Re: Installed FX Shifter in Coupe
Looks nice how much and maybe u should have gotten a pro to install it?
Old Jun 15, 2003 | 07:49 PM
Balzac72's Avatar
G SQUAD
So then is yours "just right" or is it fubar?
2003.5 - G35 6spd - Diamond Graphite/Graphite leather, prem, aero package/kit
Old Jun 15, 2003 | 07:58 PM
35C's Avatar
35C
Its perfect and I am a professional at stuff like this. The description of what had to do is just too long to type. If your good with your hands and have mechanical ability you can surely pull it off,but you must have patience because as I said its trial and error,but being that your shaving plastic down,you can take material away but you cant put it back.Most of the shaving is to the tan plastic plunger that engages the button,so if you mess up, that part is probabaly cheap,but the modification to the shift **** must be flawless,as the shifter was $105
EnCr1pt3d
Jul 8, 2019 02:48 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
BasquiatPicasso
Jul 23, 2015 06:26 PM
newbdriver01
Jul 15, 2015 06:10 PM
